[10:53:28.940]收←◆\0
[10:53:29.413]收←◆\0
[10:53:29.513]收←◆€鈲醄0倐鉂葫€JQ嵢Q?* 1爈藚r^拝瘢vX珪A碕頎+蓾e.ⅰ蓬捙?+?k馘
挔V降 ?2阵Y.〩蹅掳 蕭]Jy燬?偘.V蓵审Z碎 采矏 j⑴9碖S氌敁SjcX,擔?[悅0 史W
?㈦
5mK蘸奖d㈦K5
蹅掳)掳WJy 排糁K?爅嫢c?娀?r姲&J鶢( 畺k偂?C醄皞庐L覞J?B胙颢
倕裞
矔审Z藖:犔Bc
慑,+伆X住eV﹫[皞0)姳W
?伒仸澁捳鯶藖:€律0癈巅偮?蕰Jy?諣n卛?胀逡偘翃蹅掳)蕵Jy?諣▼?殏xx+掳r1&j両緬泶5秸r瑬傴b偛.着曎e媯傲娵偮?視Jy KUWk昳 T陯?送t昳?
[10:53:29.572]收←◆粋0r姶LJ鶢.V?A腡諅偔嫊5
蹅掳)聲Jy牗隟A?ス [?+瑰骩’
舰醄倐?飧WJy 烧?給磱(+?胙:爅
[倐?瓴W
? 嵲莜穒㎏偓汃》蚷 ru懪鬥脖a?俲
[倐?旯WZy 吔?轿觊 ?Wk旳甬媮d乮s躔仼
*?嵲?
泜0r??Jy牭盗eu?陚?聬醄0倐甃S陙?S?铃?捊o?2央’AM?A曔妽嶀[倐?WZy ?
灵雭㈦k?諯乧飙倐誂鼳5姏?r姺?葫犼pZ雭b飇褋f?眐’
a厽?5
[皞聨妀乄練p癦kb胪?缴 ?A式肬?I???r姼?葫€诗羛Z雭b痥?f
A惬i?9艎蹅掳)鈾簓牚+
岍雭㈦+褷諯乧偅
j奫皞聨將j両?莜?晇Z?傆敧 ╖k補+蘸殜嶀蹅掳I偄]Jy?V玨??
?[嫊A?壉e諬偮癐聶Jy犼侪穴(挄gZ双阨?W蓆’箩0皞掳b偉嬮0鳯偘偮癹
[皞0 ?W:??+蒻X
雭n?2絬KA?T嶀
[10:53:29.671]收←◆[0倐鉂葫€j瞪
覅i?焦fZr2秸n笰B(U偮怚⒉]Jy?V玨b仲 Z.
巡賾?Z+K遽嬮ザ
[10:53:29.720]收←◆萚倐癐拾WZy 傫嶙莶[毥n蚪褷肢筪€
憤醄0倐鉂J鶂▊潆諐!H\0?鄊ain enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0000.334] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.334] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.335] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.336] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.341] W> device prod register failed
[0000.345] I> gpio framework initialized
[0000.349] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0000.356] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0000.364] I> No valid sdcard_params in mb1_bct
[0000.368] I> Boot_device: SDMMC_BOOT instance: 3
[0000.373] I> sdmmc-3 params source = boot args
[0000.382] I> sdmmc-3 params source = boot args
[0000.382] I> sdmmc bdev is already initialized
[0000.415] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.431] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.432] I> Active Boot chain : 0
[10:53:29.918]收←◆[0000.490] I> Relocating BR-BCT
[0000.492] > DEVICE_PROD: device prod is not initialized.
[0000.517] E> I2C: slave not found in slaves.
[0000.518] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.519] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.520] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.520] E> eeprom: Failed to read I2C slave device
[0000.524] I> Failed to read CVB eeprom data @ AE
[0000.529] I> Retrying CVB eeprom read @ AC …
[0000.534] E> I2C: slave not found in slaves.
[0000.538] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0000.545] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.551] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0000.560] E> eeprom: Failed to read I2C slave device
[0000.565] I> Failed to read CVB eeprom data @ AC
[10:53:30.041]收←◆[0000.615] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0000.616] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.616] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0000.617] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0000.617] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.618] I> dram_block larger than 80000000
[0000.620] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.632] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.646] I> found decompressor handler: lz4
[10:53:30.571]收←◆[0001.141] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.143] I> Setting EKB blob info to OPTEE dtb finished.
銷OTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
[10:53:30.670]收←◆?
[10:53:30.777]收←◆銲/TC: Non-secure external DT found
[10:53:30.839]收←◆鈈pmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
[10:53:30.898]收←◆clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
[10:53:31.010]收←◆銲/TC: OP-TEE version: 3.19 (gcc vers鈇vfs_clk_platform initialized
鋓on 9.3.0 (鈙octherm initialized
銪u鈇otag initialized
鋓l鈖owergate initialized
鋎root 2020.08)) #2 Sun Mar 19 15:02:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/鈊vs initialized
鋋r鈖m initialized
鋍鈙uspend initialized
鋒ite鈖g_late initialized
鋍鈖g_mrq_init initialized
strap initialized
鋞u鈔vl initialized
鋜e/porting鈋mc initialized
emc_mrq initialized
鋉guidelines.html
I/TC: Primary CPU initializing
鈉lk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] 銲/TC: Primary CPU switching to normal world boot
[0001.794] I> Welcome to NVDisp-Init
[0001.795] I> NVDisp-Init version: t194-709c0123
[0001.795] I> CPU-BL Params @ 0xca020000
[0001.795] I> 0) Base:0x00000000 Size:0x00000000
[0001.796] I> 1) Base:0xc8100000 Size:0x00100000
[0001.796] I> 2) Base:0xc9800000 Size:0x00200000
[0001.796] I> 3) Base:0xc8600000 Size:0x00200000
[0001.799] I> 4) Base:0xc8000000 Size:0x00100000
[0001.803] I> 5) Base:0xc7f00000 Size:0x00100000
[0001.808] I> 6) Base:0xc9400000 Size:0x00400000
[0001.812] I> 7) Base:0xc9000000 Size:0x00400000
[0001.817] I> 8) Base:0xc7e00000 Size:0x00100000
[0001.821] I> 9) Base:0xc7d00000 Size:0x00100000
[0001.826] I> 10) Base:0xca800000 Size:0x00800000
[0001.830] I> 11) Base:0x40000000 Size:0x00040000
[0001.835] I> 12) Base:0xc7c00000 Size:0x00100000
[0001.839] I> 13) Base:0x40046000 Size:0x00002000
[0001.843] I> 14) Base:0x40048000 Size:0x00002000
[0001.848] I> 15) Base:0xaf000000 Size:0x00004000
[0001.852] I> 16) Base:0x4004a000 Size:0x00002000
[0001.857] I> 17) Base:0xc7a00000 Size:0x00100000
[0001.861] I> 18) Base:0x4004c000 Size:0x00002000
[0001.866] I> 19) Base:0xc9a00000 Size:0x00600000
[0001.870] I> 20) Base:0x4004e000 Size:0x00002000
[0001.875] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0001.879] I> 22) Base:0x00000000 Size:0x00000000
[0001.884] I> 23) Base:0xc7be0000 Size:0x00020000
[0001.888] I> 24) Base:0xcc000000 Size:0x02000000
[0001.893] I> 25) Base:0x40050000 Size:0x00002000
[0001.897] I> 26) Base:0x40040000 Size:0x00006000
[0001.901] I> 27) Base:0xc8c00000 Size:0x00400000
[0001.906] I> 28) Base:0xc8400000 Size:0x00200000
[0001.910] I> 29) Base:0xc8800000 Size:0x00400000
[0001.915] I> 30) Base:0xc7bd0000 Size:0x00010000
[0001.919] I> 31) Base:0x00000000 Size:0x00000000
[0001.924] I> 32) Base:0xf8000000 Size:0x08000000
[0001.928] I> 33) Base:0xce000000 Size:0x2a000000
[0001.933] I> 34) Base:0xcb000000 Size:0x01000000
[0001.937] I> 35) Base:0xae000000 Size:0x01000000
[0001.942] I> 36) Base:0xa0000000 Size:0x0e000000
[0001.946] I> 37) Base:0xca000000 Size:0x00800000
[0001.951] I> 38) Base:0x80000000 Size:0x20000000
[0001.955] I> 39) Base:0xb0000000 Size:0x08000000
[0001.959] I> 40) Base:0x00000000 Size:0x00000000
[0001.964] I> 41) Base:0x00000000 Size:0x00000000
[0001.968] I> 42) Base:0xc8200000 Size:0x00200000
[0001.973] I> 43) Base:0x00000000 Size:0x00000000
[0001.977] I> 44) Base:0x00000000 Size:0x00000000
[0001.982] I> 45) Base:0x00000000 Size:0x00000000
[0001.986] GIC-SPI Target CPU: 0
[0001.989] Interrupts Init done
[0001.992] calling constructors
[0001.995] initializing heap
[0001.998] I> Heap: [0xa0960000 … 0xadf00000]
[0002.002] initializing threads
[0002.005] initializing timers
[0002.008] creating bootstrap completion thread
[0002.012] top of bootstrap2()
[0002.015] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.019] initializing platform
[0002.022] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.028] W> device prod register failed
[0002.031] I> Bl_dtb @0xadf00000
[0002.034] I> gpio framework initialized
[0002.047] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.052] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.057] I> fixed regulator driver initialized
[0002.076] I> register ‘maxim’ power off handle
[0002.078] I> virtual i2c enabled
[0002.079] I> registered ‘maxim,max20024’ pmic
[0002.079] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.079] I> Boot-device: eMMC
[0002.080] I> Boot_device: SDMMC_BOOT instance: 3
[0002.085] I> sdmmc-3 params source = boot args
[0002.088] W> No board IDs available
[0002.091] E> Failed to get board id info!
[0002.095] I> sdmmc bdev is already initialized
[0002.099] I> sdmmc-3 params source = boot args
[0002.105] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.111] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.133] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.138] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.139] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.139] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.140] E> cannot find any other nvdisp nodes
[0002.140] E> no valid display unit config found in dtb
[0002.148] W> display init failed
[0002.148] initializing target
[0002.151] calling apps_init()
[0002.154] starting app kernel_boot_app
[0002.158] I> Kernel type = Normal
[10:53:34.301]收←◆
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
[10:53:34.463]收←◆
[10:53:34.945]收←◆
[10:53:35.056]收←◆
[10:53:35.256]收←◆
[10:53:35.277]收←◆
[10:53:35.309]收←◆
[10:53:35.359]收←◆
[10:53:35.385]收←◆
[10:53:35.442]收←◆
[10:53:35.466]收←◆
[10:53:35.496]收←◆
[10:53:35.545]收←◆
[10:53:35.575]收←◆
[10:53:35.603]收←◆
[10:53:35.657]收←◆
[10:53:35.686]收←◆
[10:53:35.719]收←◆
[10:53:35.772]收←◆
[10:53:35.795]收←◆
[10:53:35.822]收←◆
[10:53:35.873]收←◆
[10:53:35.901]收←◆
[10:53:35.947]收←◆
[10:53:35.998]收←◆
[10:53:36.030]收←◆
[10:53:36.056]收←◆
[10:53:36.092]收←◆
[10:53:36.125]收←◆
[10:53:36.171]收←◆
[10:53:36.226]收←◆
[10:53:36.253]收←◆
[10:53:36.285]收←◆
[10:53:36.343]收←◆
[10:53:36.370]收←◆
[10:53:36.444]收←◆
[10:53:36.518]收←◆
[10:53:36.561]收←◆
[10:53:36.601]收←◆
[10:53:36.868]收←◆
[10:53:36.902]收←◆
[10:53:36.935]收←◆
[10:53:36.967]收←◆
[10:53:36.997]收←◆
[10:53:37.049]收←◆
[10:53:37.124]收←◆
[10:53:37.152]收←◆
[10:53:37.207]收←◆
[10:53:37.231]收←◆
[10:53:37.259]收←◆
[10:53:37.317]收←◆
[10:53:37.343]收←◆
[10:53:37.375]收←◆
[10:53:37.402]收←◆
[10:53:37.454]收←◆
[10:53:37.506]收←◆
[10:53:37.529]收←◆
[10:53:37.572]收←◆
[10:53:37.623]收←◆
[10:53:37.654]收←◆
[10:53:37.722]收←◆
[10:53:37.776]收←◆
[10:53:37.825]收←◆
[10:53:38.015]收←◆
[10:53:38.043]收←◆
[10:53:38.344]收←◆
[10:53:38.390]收←◆
[10:53:38.428]收←◆
[10:53:38.475]收←◆
[10:53:38.504]收←◆
[10:53:38.527]收←◆
[10:53:38.560]收←◆
[10:53:38.587]收←◆
[10:53:38.684]收←◆
[10:53:38.729]收←◆
[10:53:38.939]收←◆
[10:53:39.011]收←◆
[10:53:40.275]收←◆
[10:53:40.319]收←◆
[10:53:40.355]收←◆
[10:53:40.494]收←◆
[10:53:40.572]收←◆
[10:53:42.095]收←◆ASSERT [XhciDxe] /out/nvidia/bootloader/uefi/Jetson_RELEASE/edk2/MdeModulePkg/Bus/Pci/XhciDxe/Xhci.c(2056): !((((BOOLEAN)(((XhcReadOpReg ((Xhc), (0x0004))) & ((0x00000800))) == ((0x00000800))))))
Resetting the system in 5 seconds.
[10:53:47.095]收←◆?釹hutdown state requested 1
Rebooting system …
\0
[10:53:47.157]收←◆\0鈯[悅0 Wz?扨铡E偼(偄Z+蓎捙? 禭+?释A靀蓙t?
拝雁乴
拏娈珌H?胀e.﹫蹅偘 虿WJy S?偘.V蓵蓅Z藡偛刹?將甏L?佑陯l塓5S博C?偘r露陙?B胙璠嫊:犺嫅b胙嶀+偮?趹Jy 排糁K?€J隋c?奫皞庐?WJ??
乺k
覡P覡C醄皞0 ?WJ?傠
蒾[倕雁
驎r弛?:姫爄莶n盅l^倕雁珣[0倐覞J?A誂鎉?視v㎞膣 '傴&聧?掳r赂?J?襒
挄羇?2誷Y覡铝嶀+?r?闍?R卪€菿諣’傴&H粋0r偣LJ鶢钛齭k摄Y’偮?€窝届YW朘赂倘[皞庐?WJ?码癍顿Y’殤蚐(B姽s?+蘸殜嶀[皞庐桃絁?髺珝 剶晜 [嫊5奫皞0)姷WJ?傠
c+孱j浙+攻s?
}翪醄皞聨屖陙I?醪n枊丅oKu?女毐絫’妽峄?r姴&J鶢║?KU?ス:傗?W氧?蕩厌桝?濋 ?釠?r姴N簓?u慱ㄊJデ’v﹍偵"糯X ?彦燴
j ??暕圼倐?诘Wy U祊Y醪Y陘唫?C峄?r姵陙?Z璱铃?捊o?2絩耠’AM?A誣獚嶀+掳r蕯F:??
羒?給.2杯:€u佭P%5
[倐?舛WZy ?
灵kA㈦k?諯乧飙倎晑岯℉x+偮?拾W簓 ?
岍雭㈦k?諯乧偂赎5A曔妽嶀+聬r1M?:?搈
羒kA怆汪2缴 媯肞j
[皞聨?陙W練桐羒?給.2莶杯:呂鳾悅0)渤W
?傠
5dYW+蘸?5Mi+厌+蘸毆嶀蹅掳)簹]Jy?V玨??
偁[嫊 ?壉e諬鴽偮?郝]Jy犼说E?挄gZ双呹闋*W蓆’箩0皞掳b Q嬮0鳯掳偮恓
泜0r姼M葫牏r[
毥佴?r窖 肢寡燴
厌[0倐甃跐葫€j瞪
覅i?焦fZr2秸n?B(U偮癐姫]Jy?V玨b?释A酜晠d笿攻tZ8嬮ザ
[10:53:47.364]收←◆熔偮癐矈]簓爞眳t?c速?步t€?筪J鶢≦5
[10:53:47.400]收←◆[倐癐实WJy S?⒔佶C鳿0?鄊ain enter
HW Function test
Start Scheduler.
in late init
[0000.305] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.305] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.306] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.307] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.312] W> device prod register failed
[0000.316] I> gpio framework initialized
[0000.320] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0000.327] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0000.335] I> No valid sdcard_params in mb1_bct
[0000.339] I> Boot_device: SDMMC_BOOT instance: 3
[0000.343] I> sdmmc-3 params source = boot args
[0000.353] I> sdmmc-3 params source = boot args
[0000.353] I> sdmmc bdev is already initialized
[0000.386] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.402] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.403] I> Active Boot chain : 1
[10:53:47.565]收←◆[0000.461] I> Relocating BR-BCT
[0000.463] > DEVICE_PROD: device prod is not initialized.
[0000.488] E> I2C: slave not found in slaves.
[0000.489] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.490] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.491] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.492] E> eeprom: Failed to read I2C slave device
[0000.495] I> Failed to read CVB eeprom data @ AE
[0000.500] I> Retrying CVB eeprom read @ AC …
[0000.505] E> I2C: slave not found in slaves.
[0000.509] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0000.516] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.522] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0000.531] E> eeprom: Failed to read I2C slave device
[0000.536] I> Failed to read CVB eeprom data @ AC
[0000.586] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0000.587] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.588] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0000.588] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0000.588] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.589] I> dram_block larger than 80000000
[0000.591] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.603] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.617] I> found decompressor handler: lz4
[10:53:48.221]收←◆[0001.113] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.114] I> Setting EKB blob info to OPTEE dtb finished.
I/TC:
[10:53:48.322]收←◆?
[10:53:48.426]收←◆銲/TC: Non-secure external DT found
[10:53:48.483]收←◆鈈pmp: init
[10:53:48.543]收←◆clk_early initialized
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
mc initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmon initialized
[10:53:48.657]收←◆銲/TC: OP-TEE version: 3.19 (gcc 鈇vfs_clk_platform initialized
鋠ersion 9.3鈙octherm initialized
?0鈇otag initialized
?(鈖owergate initialized
Buildroot 2020.08)) #2 Sun Mar 19 15:02:42 UTC 2023 aarch64
I/TC: WARNING: Please check (此处发帖不能重复出现进行了更改)
鋝鈖m initialized
鋞/鈙uspend initialized
鋋rc鈖g_late initialized
鋒i鈖g_mrq_init initialized
strap initialized
鋞鈔vl initialized
鋏cture/por鈋mc initialized
emc_mrq initialized
鋞ing_guidelines.html
鈉lk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ec_mrq initialized
clk_mrq initialized
i2c_mrq initialized
tag_mrq initialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
profile initialized
bpmp: init complete
[10:53:48.854]收←◆銲/TC: Primary CPU switching to normal world boot
[0001.766] I> Welcome to NVDisp-Init
[0001.766] I> NVDisp-Init version: t194-709c0123
[0001.766] I> CPU-BL Params @ 0xca020000
[0001.767] I> 0) Base:0x00000000 Size:0x00000000
[0001.767] I> 1) Base:0xc8100000 Size:0x00100000
[0001.767] I> 2) Base:0xc9800000 Size:0x00200000
[0001.768] I> 3) Base:0xc8600000 Size:0x00200000
[0001.770] I> 4) Base:0xc8000000 Size:0x00100000
[0001.775] I> 5) Base:0xc7f00000 Size:0x00100000
[0001.779] I> 6) Base:0xc9400000 Size:0x00400000
[0001.784] I> 7) Base:0xc9000000 Size:0x00400000
[0001.788] I> 8) Base:0xc7e00000 Size:0x00100000
[0001.793] I> 9) Base:0xc7d00000 Size:0x00100000
[0001.797] I> 10) Base:0xca800000 Size:0x00800000
[0001.801] I> 11) Base:0x40000000 Size:0x00040000
[0001.806] I> 12) Base:0xc7c00000 Size:0x00100000
[0001.810] I> 13) Base:0x40046000 Size:0x00002000
[0001.815] I> 14) Base:0x40048000 Size:0x00002000
[0001.819] I> 15) Base:0xaf000000 Size:0x00004000
[0001.824] I> 16) Base:0x4004a000 Size:0x00002000
[0001.828] I> 17) Base:0xc7a00000 Size:0x00100000
[0001.833] I> 18) Base:0x4004c000 Size:0x00002000
[0001.837] I> 19) Base:0xc9a00000 Size:0x00600000
[0001.842] I> 20) Base:0x4004e000 Size:0x00002000
[0001.846] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0001.851] I> 22) Base:0x00000000 Size:0x00000000
[0001.855] I> 23) Base:0xc7be0000 Size:0x00020000
[0001.859] I> 24) Base:0xcc000000 Size:0x02000000
[0001.864] I> 25) Base:0x40050000 Size:0x00002000
[0001.868] I> 26) Base:0x40040000 Size:0x00006000
[0001.873] I> 27) Base:0xc8c00000 Size:0x00400000
[0001.877] I> 28) Base:0xc8400000 Size:0x00200000
[0001.882] I> 29) Base:0xc8800000 Size:0x00400000
[0001.886] I> 30) Base:0xc7bd0000 Size:0x00010000
[0001.891] I> 31) Base:0x00000000 Size:0x00000000
[0001.895] I> 32) Base:0xf8000000 Size:0x08000000
[0001.900] I> 33) Base:0xce000000 Size:0x2a000000
[0001.904] I> 34) Base:0xcb000000 Size:0x01000000
[0001.909] I> 35) Base:0xae000000 Size:0x01000000
[0001.913] I> 36) Base:0xa0000000 Size:0x0e000000
[0001.917] I> 37) Base:0xca000000 Size:0x00800000
[0001.922] I> 38) Base:0x80000000 Size:0x20000000
[0001.926] I> 39) Base:0xb0000000 Size:0x08000000
[0001.931] I> 40) Base:0x00000000 Size:0x00000000
[0001.935] I> 41) Base:0x00000000 Size:0x00000000
[0001.940] I> 42) Base:0xc8200000 Size:0x00200000
[0001.944] I> 43) Base:0x00000000 Size:0x00000000
[0001.949] I> 44) Base:0x00000000 Size:0x00000000
[0001.953] I> 45) Base:0x00000000 Size:0x00000000
[0001.958] GIC-SPI Target CPU: 0
[0001.961] Interrupts Init done
[0001.964] calling constructors
[0001.966] initializing heap
[0001.969] I> Heap: [0xa0960000 … 0xadf00000]
[0001.973] initializing threads
[0001.976] initializing timers
[0001.979] creating bootstrap completion thread
[0001.983] top of bootstrap2()
[0001.986] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.991] initializing platform
[0001.994] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.999] W> device prod register failed
[0002.003] I> Bl_dtb @0xadf00000
[0002.006] I> gpio framework initialized
[0002.018] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.026] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.031] I> fixed regulator driver initialized
[0002.049] I> register ‘maxim’ power off handle
[0002.052] I> virtual i2c enabled
[0002.052] I> registered ‘maxim,max20024’ pmic
[0002.052] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.053] I> Boot-device: eMMC
[0002.053] I> Boot_device: SDMMC_BOOT instance: 3
[0002.057] I> sdmmc-3 params source = boot args
[0002.060] W> No board IDs available
[0002.062] E> Failed to get board id info!
[0002.066] I> sdmmc bdev is already initialized
[0002.070] I> sdmmc-3 params source = boot args
[0002.077] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.082] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.103] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.109] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.110] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.110] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.111] E> cannot find any other nvdisp nodes
[0002.112] E> no valid display unit config found in dtb
[0002.119] W> display init failed
[0002.120] initializing target
[0002.123] calling apps_init()
[0002.125] starting app kernel_boot_app
[0002.129] I> Kernel type = Normal
[10:53:51.944]收←◆
[10:53:52.100]收←◆
[10:53:52.586]收←◆
[10:53:52.700]收←◆
[10:53:52.733]收←◆
[10:53:52.926]收←◆
[10:53:52.957]收←◆
[10:53:52.984]收←◆
[10:53:53.029]收←◆
[10:53:53.058]收←◆
[10:53:53.105]收←◆
[10:53:53.137]收←◆
[10:53:53.167]收←◆
[10:53:53.220]收←◆
[10:53:53.249]收←◆
[10:53:53.275]收←◆
[10:53:53.332]收←◆
[10:53:53.356]收←◆
[10:53:53.390]收←◆
[10:53:53.421]收←◆
[10:53:53.481]收←◆
[10:53:53.525]收←◆
[10:53:53.590]收←◆
[10:53:53.620]收←◆
[10:53:53.679]收←◆
[10:53:53.712]收←◆
[10:53:53.778]收←◆
[10:53:53.807]收←◆
[10:53:53.863]收←◆
[10:53:53.886]收←◆
[10:53:53.932]收←◆
[10:53:54.017]收←◆
[10:53:54.044]收←◆
[10:53:54.097]收←◆
[10:53:54.121]收←◆
[10:53:54.217]收←◆
[10:53:54.256]收←◆
[10:53:54.280]收←◆
[10:53:54.444]收←◆
[10:53:54.475]收←◆
[10:53:54.499]收←◆
[10:53:54.533]收←◆
[10:53:54.567]收←◆
[10:53:54.596]收←◆
[10:53:54.629]收←◆
[10:53:54.714]收←◆
[10:53:54.765]收←◆
[10:53:54.794]收←◆
[10:53:54.824]收←◆
[10:53:54.880]收←◆
[10:53:54.901]收←◆
[10:53:54.933]收←◆
[10:53:54.965]收←◆
[10:53:55.002]收←◆
[10:53:55.035]收←◆
[10:53:55.067]收←◆
[10:53:55.118]收←◆
[10:53:55.139]收←◆
[10:53:55.177]收←◆
[10:53:55.206]收←◆
[10:53:55.233]收←◆
[10:53:55.259]收←◆
[10:53:55.325]收←◆
[10:53:55.371]收←◆
[10:53:55.602]收←◆
[10:53:55.632]收←◆
[10:53:55.939]收←◆
[10:53:55.983]收←◆
[10:53:56.022]收←◆
[10:53:56.059]收←◆
[10:53:56.091]收←◆
[10:53:56.146]收←◆
[10:53:56.171]收←◆
[10:53:56.239]收←◆
[10:53:56.261]收←◆
[10:53:56.323]收←◆
[10:53:56.531]收←◆
[10:53:56.597]收←◆
[10:53:57.858]收←◆
[10:53:57.902]收←◆
[10:53:57.964]收←◆
[10:53:58.152]收←◆
[10:53:59.674]收←◆ASSERT [XhciDxe] /out/nvidia/bootloader/uefi/Jetson_RELEASE/edk2/MdeModulePkg/Bus/Pci/XhciDxe/Xhci.c(2056): !((((BOOLEAN)(((XhcReadOpReg ((Xhc), (0x0004))) & ((0x00000800))) == ((0x00000800))))))
[10:54:04.674]收←◆?釹hutdown state requested 1
Rebooting system …
\0
[10:54:04.736]收←◆\0鈯蹅掳 ]簓?眱猀i S?挜籴.伈X住e矃训Y鉅?b吷鏨.ⅰ卬爊褝hYb斩Y
?柦mB潬柾晄?醄皞庐?WJ??偍蒬峎烷雐牔Ir聨jtL.搲娳秤撌-碝S矈嶀+偮?蚋WJy KU瓔曢 K娠K奫倐?Wy e鹏諯礽爅嫢c?奫皞0 撼WJ??
rYW+屣
覡P襽醄倐0 憾W
?㈦K蒾[倕瘢
視r薃簥隊i缴rY,?乸醀d?醄皞庐乱絁?習A?挄vZ鶢’赂&俲
[倐?碌Wy ?吪?胀e覀傲娀?r偢陙?RXeY覡律嶀[0倐蕽J?r.?畷?悏,捦襞斩Y?0艎[皞聨?WJ?码嫷d+蘸殤蚐(BsWY’殜嶀泜0r姳&J鶢.V玨DU倐瓔?
[皞0)?WJ?傠
c+錸j浙+攻s?
}翪醄皞庐淌陙I?醪n枊仮隟u?女毐絫’傖[倐?挷W*?缴?醪.枊伋隟A?农k闋畗塴’傴撆碮Vb .解畟傲娵偮?覙Jy?謺駹?挄峯咨鵭荬偃\0
