这个问题已经解决了,但是又有新问题啊
0x10009825 处未处理的异常: 0xC0000005: 读取位置 0xcdcdcdd1 时发生访问冲突
这个一般是什么原因啊??出现在分配显存的时候
错误	14	error LNK2005: __Z15integrateBodiesP6float4S0_Pl 已经在 myfirst.obj 中定义	myfirst_kernel.obj
错误	15	error LNK2005: ___device_stub__Z15integrateBodiesP6float4S0_Pl 已经在 myfirst.obj 中定义	myfirst_kernel.obj
错误	16	error LNK2005: "void __cdecl integrateBodies__entry(struct float4 *,struct float4 *,long *)" (?integrateBodies__entry@@YAXPAUfloat4@@0PAJ@Z) 已经在 myfirst.obj 中定义	myfirst_kernel.obj
错误	17	fatal error LNK1169: 找到一个或多个多重定义的符号	C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src\Project2\EmuDebug\Project2.exe
我的原程序如下:
//this is file myfirst.cu
#include "myfirst_kernel.cu"
#include "myfirst.h"
//#include <cutil_inline.h>
#include "cutil.h"
#include <cstdio>
#include <cstdlib>
#include <stdlib.h>
#include <time.h>
//added 2010.3.22
#include <string.h>
#include <math.h>
extern "C"
   int main( int argc,char** argv)  //the main program added by zhoulin 2010.3.4
	CUT_DEVICE_INIT(argc, argv);
	// 4 floats each for alignment reasons
	unsigned int memSize = sizeof( float4) * numBodies;
	//host端分配内存
	clock_t * timer=NULL;   //我们这里并非是计算一个block的时间,而是总共的运算时间
	float4* h_pos=(float4*)malloc(numBodies);
	float3* h_acc=(float3*)malloc(numBodies);
	float4* h_vel=(float4*)malloc(numBodies);
	//生成初试数据  bodysystemcpu.cpp
   float alat=1.5496;
   float disp=0.5;
   float rcell[3][4]={0.0,0.0,0.0,0.5,0.5,0.0,0.0,0.5,0.5,0.5,0.0,0.5};
   srand(int(time(NULL)/2));
   for(int k=0;k<8;k++)
   for(int j=0;j<8;j++)
   for(int i=0;i<4;i++)
   for(int L=0;L<4;L++)
			int index=k*8+j*8+i*4+L*4;
			h_pos[index].x=alat*(i+rcell[1][L])+2.0*disp*(rand()/(float)RAND_MAX-0.5);
			h_pos[index].y=alat*(i+rcell[2][L])+2.0*disp*(rand()/(float)RAND_MAX-0.5);
			h_pos[index].z=alat*(i+rcell[3][L])+2.0*disp*(rand()/(float)RAND_MAX-0.5);
			h_pos[index].w=1.0;
			h_vel[index].x=0.0;
			h_vel[index].y=0.0;
			h_vel[index].z=0.0;
			h_vel[index].w=0.0;
			printf("位置:%f-%f-%f-%f\n",h_pos[index].x,h_pos[index].y,h_pos[index].z);
			printf("速度:%f-%f-%f-%f\n",h_vel[index].x,h_vel[index].y,h_vel[index].z);
	//device端分配内存
   clock_t* dtimer=NULL;
	cudaMalloc((void**)&dtimer, sizeof(clock_t)*16*2);
   float4* d_pos=NULL;
	cudaMalloc((void**)&d_pos, numBodies);
	float3* d_acc=NULL;
	cudaMalloc((void**)&d_acc, numBodies);
	float4* d_vel=NULL;
	cudaMalloc((void**)&d_vel, numBodies);
	//向显存拷入数据
	CUDA_SAFE_CALL(cudaMemcpy(d_pos, h_pos, memSize,cudaMemcpyHostToDevice));
		//运行核函数
	//int sharedMemSize = 3*p * sizeof(float4); // each 4 floats for pos,vel and acc
   dim3 threads(p,1,1);
	dim3 grid(16, 1, 1);
	   // execute the kernel: we set q=1 here.-----zhoulin 2010.3.4
	integrateBodies<<< grid, threads,memSize >>>(d_pos, d_vel,dtimer);
   	// check if kernel invocation generated an error
	 CUT_CHECK_ERROR("Kernel execution failed");
	//将数据拷回主机内存
   CUDA_SAFE_CALL(cudaMemcpy(timer, dtimer,memSize, cudaMemcpyDeviceToHost));
   CUDA_SAFE_CALL(cudaMemcpy(h_pos, d_pos, memSize, cudaMemcpyDeviceToHost));
	CUDA_SAFE_CALL(cudaMemcpy(h_vel, d_vel, memSize, cudaMemcpyDeviceToHost));
	//释放存储器
	//cuda_safe_call(cudaFreeHost(h_pos));
   //cuda_safe_call(cudaFreeHost(h_acc));
	//cuda_safe_call(cudaFreeHost(h_vel));
	free(h_pos);
   free(h_acc);
	free(h_vel);
	CUDA_SAFE_CALL(cudaFree(d_pos));
	CUDA_SAFE_CALL(cudaFree(d_acc));
	CUDA_SAFE_CALL(cudaFree(d_vel));
	CUDA_SAFE_CALL(cudaFree(dtimer));
	//时间测试
   clock_t minStart = timer[0];
   clock_t maxEnd = timer[16];
   for (int i = 1; i < 16; i++)
   minStart = timer[i] < minStart ? timer[i] : minStart;
   maxEnd = timer[16+i] > maxEnd ? timer[16+i] : maxEnd;
   printf("time = %d\n", maxEnd - minStart);
	CUT_EXIT(argc, argv);  //exit CUDA
/* this is the file myfirst_kernel.cu
#ifndef _MYFIRST_KERNEL_H_
#define _MYFIRST_KERNEL_H_
#include <math.h>
#define LOOP_UNROLL 4
// Macros to simplify shared memory addressing
#define SX(i) sharedPos[i+blockDim.x*threadIdx.y]
__device__ float3 bodyBodyInteraction(float3 ai, float4 bi, float4 bj)
   float3 r;
   // r_ij  [3 FLOPS]
   r.x = bi.x - bj.x;
   r.y = bi.y - bj.y;
   r.z = bi.z - bj.z;
   // distSqr = dot(r_ij, r_ij) + EPS^2  [6 FLOPS]
   float distSqr = r.x * r.x + r.y * r.y + r.z * r.z;
   distSqr += eps;
   // invDistCube =1/distSqr^(3/2)  [4 FLOPS (2 mul, 1 sqrt, 1 inv)]
   float invDist = 1.0f / sqrtf(distSqr);
	float invDistCube =  invDist * invDist * invDist;
   //float distSixth = distSqr * distSqr * distSqr;
   //float invDistCube = 1.0f / sqrtf(distSixth);
   // s = m_j * invDistCube [1 FLOP]
   float s = bj.w * invDistCube;
   // a_i =  a_i + s * r_ij [6 FLOPS]
   ai.x += r.x * s;
   ai.y += r.y * s;
   ai.z += r.z * s;
   return ai;
// This is the "tile_calculation" function from the GPUG3 article.
__device__ float3 gravitation(float4 myPos, float3 accel)
   extern __shared__ float4 sharedPos[];
   long i=0;
   for (unsigned int counter = 0; counter < blockDim.x; )
   accel = bodyBodyInteraction(accel, SX(i++), myPos);
	counter++;
#if LOOP_UNROLL > 1
	counter++;
#endif
#if LOOP_UNROLL > 2
	counter += 2;
#endif
#if LOOP_UNROLL > 4
	counter += 4;
#endif
   return accel;
__device__ float3 computeBodyAccel(float4 bodyPos, float4* positions)
   float3 acc = {0.0f, 0.0f, 0.0f};
   int numTiles = numBodies / (p * q);
   int gtid = blockIdx.x * blockDim.x + threadIdx.x;
   for (int tile = blockIdx.y; tile < numTiles + blockIdx.y; tile++)
   sharedPos[gtid] = positions[gtid];
   acc = gravitation(bodyPos, acc);
   return acc;
__global__ void
integrateBodies(float4* oldPos, float4* oldVel,clock_t* timer)
   int index = __mul24(blockIdx.x,blockDim.x) + threadIdx.x;
	if (threadIdx.x==0)  timer[blockIdx.x]=clock();
   float4 pos = oldPos[index];
   float3 accel = computeBodyAccel(pos, oldPos);
   float4 vel = oldVel[index];
   vel.x += accel.x * deltaTime;
   vel.y += accel.y * deltaTime;
   vel.z += accel.z * deltaTime;
   vel.x *= damping;
   vel.y *= damping;
   vel.z *= damping;
   // new position = old position + velocity * deltaTime
   pos.x += vel.x * deltaTime;
   pos.y += vel.y * deltaTime;
   pos.z += vel.z * deltaTime;
   // store new position and velocity
   oldPos[index] = pos;
   oldVel[index] = vel;
	if (threadIdx.x==0)  timer[blockIdx.x+blockDim.x]=clock();
#endif // #ifndef _NBODY_KERNEL_H_
#ifndef _MYFIRST_H_
#define _MYFIRST_H_
#define p 64
#define q 1
#define numBodies  1024
#define deltaTime  0.01
#define damping  0.5
#define eps  0.001
#endif
[ 本帖最后由 hnuzhoulin 于 2010-3-30 15:38 编辑 ]
