JetsonNanoB01启动时卡在最后一步,进不了系统是怎么回事?
板子上我只连了一个USB转串口的监视线和一个5V电源。之前都一直好好的,可以正常启动。今天就一直进不了系统了,卡在最后一步,最后一部分的启动日志如下:
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 161 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 288 ms (18.2 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1532 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776f0
Starting kernel …
[ 1.015526] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.521701] Host read timeout at address 545c00c4 [ 1.721065] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.721097] imx219 7-0010: board setup failed [ 1.745174] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.745208] imx219 8-0010: board setup failed [ 2.614140] cgroup: cgroup2: unknown option "nsdelegate" [ 3.742652] using random self ethernet address [ 3.747460] using random host ethernet address [ 4.227897] random: crng init done [ 4.231302] random: 7 urandom warning(s) missed due to ratelimiting [ 5.005810] using random self ethernet address [ 5.013513] using random host ethernet address
无法弹出用户名输入那一行,系统进不去。我烧录的是jetpack 4.3。
正常启动日志:
Starting kernel …
[ 1.011942] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.518104] Host read timeout at address 545c00c4 [ 1.538783] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.538788] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.542106] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.542110] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.545436] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.545440] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.548679] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.548683] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.548688] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.666005] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.672473] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.683859] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.690144] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.701713] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.707990] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.719589] tegradc tegradc.1: dp: aux write got error (0x1001000f) [ 1.725865] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x1001000f [ 1.734133] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.741879] hpd: edid read prepare failed[ 1.821369] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.828918] imx219 7-0010: board setup failed [ 1.857265] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.864914] imx219 8-0010: board setup failed [ 2.585242] cgroup: cgroup2: unknown option "nsdelegate" [ 3.806636] using random self ethernet address [ 3.811242] using random host ethernet address [ 4.151306] random: crng init done [ 4.154714] random: 7 urandom warning(s) missed due to ratelimiting [ 5.178428] using random self ethernet address [ 5.183149] using random host ethernet address
Ubuntu 18.04.3 LTS nvidia-desktop ttyS0
nvidia-desktop login:
你好,现在问题解决了么,我也遇到了同样的问题,不知道怎么弄
ssh 可以连上去,但用hdmi 连显示 器黑屏,我也是报这个错误,不怎么是不是这个问题产生的。
你好,你的问题解决了嘛?
你好,你的问题解决了吗,我也遇到同样问题了
