矩阵自乘的问题
///////////////////////////// Aderivative的定义////////////////////////////////////
ADerivative = newfloat*[m_receiverm_tnum]; //30300
  for( i=0; i<m_receiver*m_tnum; ++i)
         ADerivative=new float[m_GridnumX*m_GridnumZ];//30*50
         for( j=0; j<m_GridnumX*m_GridnumZ; ++j)
                ADerivative[j]=0.0;
#defineM 30*300
#define N 30*50
float *g_ADerivative[N];
float *g_C1[N];
cudaMalloc((void**)&g_ADerivative,NMsizeof(float));
/////////// Aderivative是 new 的 不连续的地址,可不可以直接cudamemcpy////////////
cudaMemcpy(g_ADerivative,ADerivative,m_receiverm_tnumm_GridnumXm_GridnumZsizeof(float),cudaMemcpyHostToDevice);
////////////////////Aderivative的转置 * Aderivative////////////////////////////////
   MatrixMutil0(g_ADerivative,g_C1,m_receiver*m_tnum,m_GridnumX*m_GridnumZ,1,BLOCK);
void MatrixMutil0(float **Mx,float **result,intMX,int MZ,floatalpha,int thread)
   dim3 THread(thread,thread);
   dim3 BLock(MZ/thread,MZ/thread);
   g_MatrixMutil0<<<BLock,THread>>>(Mx,result,MX,MZ,alpha);
   cudaError_t cudaStatus;
   cudaStatus = cudaDeviceSynchronize();
   if(cudaStatus != cudaSuccess) {
   fprintf(stderr, "cudaDeviceSynchronizereturned error code %d after Kernel!\n", cudaStatus);}
global void g_MatrixMutil0(float**Mx,float **result,intMX,int MZ,floatalpha) {
   int x =blockIdx.x * blockDim.x + threadIdx.x;
   int y =blockIdx.y * blockDim.y + threadIdx.y;
   int tx =threadIdx.x;
   int ty =threadIdx.y;
   int bx =blockIdx.x;
   int by =blockIdx.y;
   floatsub;
   inti,j,k,a,b;
   for(i=0;i<MX/30;i++)
          float*Asub = GetSubMatrix(Mx,i,bx);
          //获取指向当前矩阵N的子矩阵的指针Nsub
          float*A_sub = GetSubMatrix(Mx,i,by);
          __shared__ float AT[BLOCK][BLOCK];
          __shared__ float A[BLOCK][BLOCK];
          AT[ty][tx]=*(A_sub+tx*BLOCK+ty);
          A[ty][tx] =*(Asub+tx*BLOCK+ty);
          for(k=0;k<BLOCK;k++)
                 sub+=AT[ty][k]*A[k][tx]*alpha;
   result[y][x]=sub;
device float* GetSubMatrix( float**A,int row ,int col)
   return&A[row*BLOCK][col*BLOCK];
程序运行报错:cudaDeviceSynchronize returnederror code 30 after Kernel!
但是有结果,结果不正确。
程序是数据传输问题,还是矩阵自乘部分的问题。烦请大神ice和横扫千军指导,谢谢!!
30号错误是cuda error unknown,
所以您的问题:“程序是数据传输问题,还是矩阵自乘部分的问题。”
的回答是:
“您的矩阵自乘的kernel有问题,而且是非法访存或者越界”。
您可以进一步通过start cuda debugging(启用memory check的情况下),一步定位到具体出错的行。
我稍微补充一下2#横扫斑竹。
您在host端申请的ADerivative是指针数组,并多次分段申请了存储空间(您的代码可能丢失了部分字符,我猜测是如此)。
而您向device端的g_ADerivative复制的时候,是一次性复制全部逻辑所需大小的,这个是不行的。非连续的地址内容,无法直接copy。以及您的float *g_ADerivative[N];float *g_C1[N];这两个数据类型似乎也和您的用法对不上。
请您考虑这个问题。
向device端的g_ADerivative复制的时候可不可以这样写:
for( i=0; i<m_receiverm_tnum; ++i)
{ cudaMemcpy(g_ADerivative[i],ADerivative[i],m_GridnumX
m_GridnumZ*sizeof(float),cudaMemcpyHostToDevice);
至于float *g_ADerivative[N],是传入GPU的矩阵;float *g_C1[N]是矩阵相乘的结果。对应核函数的参数float **Mx,float **result。
1:可以分段copy。
2:您在copy的时候,使用的存放指针的那个数组需要保存在host端,否则cudaMemcpy()这个runtime函数参数会报错。
3:您还需要定义一个存在host端的指向指针数组的指针,并cudaMalloc这个指针数组的大小,并将host端保存的指针数组复制过去,然后使用这个指向指针数组的指针作为kernel的参数。
大致如此,供您参考。
您还可以参考近期的一个讨论帖:
http://cudazone.nvidia.cn/forum/forum.php?mod=viewthread&tid=7056&extra=page%3D1
我的程序就是按照那个帖子写的。
float g_A[N];
cudaMalloc((void
*)&g_A,MNsizeof(float));
for( i=0; i<M; ++i)
cudaMemcpy(g_A,A,N*sizeof(float),cudaMemcpyHostToDevice);
//A是在主机上的二维指针数组
传递参数的时候直接使用g_A。好像会报错。有错误的话ice可不可以写个例程指出来
上述引用的讨论帖的6#就是现成的正确的例程,经 无与伦比 网友编译和运行检验通过的,请您参照。
