求大神帮忙啊
我用GPU计算X^2-X+1=0在[1,2]内的解,把[a,b]等分成64份,交给64个线程处理,找出根的范围
源代码如下://////////////////////////////////////////////////////////////////////////////
// Copyright 1993-2012 NVIDIA Corporation. All rights reserved.
// Please refer to the NVIDIA end user license agreement (EULA) associated
// with this source code for terms and conditions that govern your use of
// this software. Any use, reproduction, disclosure, or distribution of
// this software and related documentation outside the terms of the EULA
// is strictly prohibited.
/* Template project which demonstrates the basics on how to setup a project
  • example application.
  • Host code.
// includes, system
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include
#define F(x) (x*x-x+1)
// includes CUDA
#include <cuda_runtime.h>
// includes, project
#include <helper_cuda.h>
#include <helper_functions.h> // helper functions for SDK examples
// declaration, forward
void runTest(int argc, char **argv);
using std::endl;
using std::cout;
global void
FindAnswer(float *g_A,float *g_B, float *g_C)
int tid=threadIdx.x;
int bid=blockIdx.x;
float a=*g_A;
float b=*g_B;
float New_a,New_b;
do
New_a=*g_A+(g_B-g_A)/64(bidblockDim.x+tid);
New_b=g_A+(g_B-g_A)/64(bidblockDim.x+tid+1);
if((F(New_a))
(F(New_b))<0)
*g_A=New_a;
*g_B=New_b;
while(fabs(*g_B-*g_A)>0.001);
if(!(a==*g_A&&b==g_B)&&(bidblockDim.x+tid)==0)
*g_C=(*g_A+*g_B)/2;
// Program main
int
main(int argc, char **argv)
runTest(argc, argv);
//! Run a simple test for CUDA
void
bool bTestResult = true;
printf(“%s Starting…\n\n”, argv[0]);
cudaError_t err=cudaSuccess;
// use command-line specified CUDA device, otherwise use device with highest Gflops/s
int devID = findCudaDevice(argc, (const char **)argv);
StopWatchInterface *timer = 0;
sdkCreateTimer(&timer);
sdkStartTimer(&timer);
unsigned int num_threads = 32;
size_t mem_size = sizeof(float) *1;
// allocate host memory
float *h_A = (float *) malloc(mem_size);
float *h_B = (float *) malloc(mem_size);
// initalize the memory
h_A[0]=1;
h_B[0]=2;
// allocate device memory
float *d_A=NULL;
float *d_B=NULL;
err=cudaMalloc((void **) &d_A, mem_size);
err=cudaMalloc((void **) &d_B, mem_size);
// copy host memory to device
err=cudaMemcpy(d_A, h_A, mem_size,
cudaMemcpyHostToDevice);
err=cudaMemcpy(d_B, h_B, mem_size,
// allocate device memory for result
float *d_C;
checkCudaErrors(cudaMalloc((void **) &d_C, mem_size));
// setup execution parameters
//dim3 grid(2, 1, 1);
//dim3 threads(num_threads, 1, 1);
// execute the kernel
FindAnswer<<<2,32>>>(d_A, d_B,d_C);
// check if kernel execution generated and error
getLastCudaError(“Kernel execution failed”);
// allocate mem for the result on host side
float *h_C = (float *) malloc(mem_size);
// copy result from device to host
checkCudaErrors(cudaMemcpy(h_C, d_C, mem_size,
cudaMemcpyDeviceToHost));
sdkStopTimer(&timer);
printf(“Processing time: %f (ms)\n”, sdkGetTimerValue(&timer));
sdkDeleteTimer(&timer);
std::cout<<“解为”<<*h_C;
// compute reference solution
//float *reference = (float *) malloc(mem_size);
//computeGold(reference, h_idata, num_threads);
// check result
/* if (checkCmdLineFlag(argc, (const char **) argv, “regression”))
// write file for regression test
sdkWriteFile(“./data/regression.dat”, h_odata, num_threads, 0.0f, false);
else
// custom output handling when no regression test running
// in this case check if the result is equivalent to the expected soluion
bTestResult = compareData(reference, h_odata, num_threads, 0.0f, 0.0f);
// cleanup memory
free(h_A);
free(h_B);
free(h_C);
//free(reference);
checkCudaErrors(cudaFree(d_A));
checkCudaErrors(cudaFree(d_B));
checkCudaErrors(cudaFree(d_C));
cudaDeviceReset();
exit(bTestResult ? EXIT_SUCCESS : EXIT_FAILURE);
这个程序执行时,在执行上面红色标注的行时,出错了,我单步调试到这里时,显示器就黑屏一会,下面在执行checkCudaErrors(cudaFree(d_C))时也出错了,究竟是怎么回事啊?
我不知道在VC里如何单步调试内核函数,并且看到GPU里的变量
这个问题我解决了,限定循环的次数就不再出现这个情况了,但是遇到了新的问题,发现算的结果是0.5,也就是说,循环没起到作用,怎么回事?
LZ您好,您的算法逻辑应该有一定问题。
您kernel里面的内容,大致是寻求某方程的根(曲线与x轴交点)的做法。但是有诸多问题:
1:您的这个方法只适合和x轴有一个交点的情况,如果有多个交点,那么会漏解(因为你只有一组全局的表示位置的变量),还可能进入死循环(假定有两个解但落在同一初始区间,然后这两个解都被华丽地无视了,然后大家都找不到解)。
2:您的方法即使是在只有一解的情况下,如果初始区间给的就不包含有解区间,那么整个程序也会落入死循环。
所以您的算法实现问题颇多,若kernel进入死循环,那么在超时之后,就会画面一黑,显卡驱动重启。
此外,如果您需要定位是红色的copy步骤出问题,还是前面的kernel挂了,您可以加上适当的检查CUDAError的代码,这部分内容另外一个帖子说了,不再赘述。
祝您调试顺利!
我执行结果出来了,您提的问题也是我所焦虑的,所以我也在寻找这种算法,我去查资料
LZ您好,有一些讲述计算方法的书会讲述一些常用的方程求根的数值方法,您不妨参考并考虑下是否可以并行实现。
祝您好运。
是的,CS有一门叫《数值计算》的课,里面有大量解方程的实践。要不要买一本看下?
cs是什么,我在图书馆找到《数值计算方法引论》的书,理论太强,看不懂,要找到本实践性强,又容易上手的书,不好找,没听懂楼主说的书的具体信息
嗯嗯。就是这本。《数值计算导论》没错。 如果这本还算“理论强”的书。。那么没有更具有实践意义的了。。。
嗯,可以问你,GPU里执行四重循环有没有问题?计算512512512次会不会导致黑屏?
我拒绝回答这个问题,这是对我的侮辱!
我是初次接触CUDA,而且不是计算机专业的,我真没有别的意思,如果我闹了笑话,您见谅
嗯嗯。那么这里我就对论坛的一些常见问题做一下总结性的回答:
(1)问:CUDA能用goto吗?答:可以
(2)问:CUDA能用do…while吗?答:可以
(3)问:CUDA能用局部数组,能用指针吗?答:可以
(4)问:CUDA能嵌套2层循环吗?答:可以
(5)问:CUDA能嵌套3层循环吗?答:可以
(6)问:CUDA能嵌套4层循环吗?答:可以
感谢来访。敬请参考。
嗯嗯,我编了计算角系数的CPU程序,正在调试CUDA程序,看来我的黑屏的问题不是因为四重循环的问题,我在看看有没有逻辑错误,编好后两个程序比较下,看加速效果怎么样
