OTA构建升级包过程失败
请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
[*] Jetson AGX Orin
Jetson Orin NX
Jetson Orin Nano
Jetson AGX Xavier
Jetson Xavier NX
Jetson TX 系列
Jetson Nano
Jetson 软件
JetPack 5.1.3
[*] JetPack 5.1.4
JetPack 6.0
JetPack 6.1
JetPack 6.2
DeepStream SDK
NVIDIA Isaac
问题描述
在构建OTA升级包的时候发生错误,但是之前构建的时候并没有发现过这种现象
错误日志
*UCCESS: generate APP image
Skip generating binaries for “nvme0n1p1”
‘flash.idx’ → ‘/tmp/tmp_dir_for_reserved/flash.idx’
‘boot.img’ → ‘/tmp/tmp_dir_for_reserved/boot.img’
‘kernel_tegra234-p3701-0000-p3737-0000.dtb’ → ‘/tmp/tmp_dir_for_reserved/kernel_tegra234-p3701-0000-p3737-0000.dtb’
‘recovery.img’ → ‘/tmp/tmp_dir_for_reserved/recovery.img’
‘tegra234-p3701-0000-p3737-0000.dtb.rec’ → ‘/tmp/tmp_dir_for_reserved/tegra234-p3701-0000-p3737-0000.dtb.rec’
‘esp.img’ → ‘/tmp/tmp_dir_for_reserved/esp.img’
‘/tmp/tmp_dir_for_reserved/boot.img’ → ‘./boot.img’
‘/tmp/tmp_dir_for_reserved/esp.img’ → ‘./esp.img’
‘/tmp/tmp_dir_for_reserved/flash.idx’ → ‘./flash.idx’
‘/tmp/tmp_dir_for_reserved/kernel_tegra234-p3701-0000-p3737-0000.dtb’ → ‘./kernel_tegra234-p3701-0000-p3737-0000.dtb’
‘/tmp/tmp_dir_for_reserved/recovery.img’ → ‘./recovery.img’
‘/tmp/tmp_dir_for_reserved/tegra234-p3701-0000-p3737-0000.dtb.rec’ → ‘./tegra234-p3701-0000-p3737-0000.dtb.rec’
cp: cannot stat ‘flash.idx’: No such file or directory
这个构建大约构建了快一个小时后出现的这个报错,我没办法提供更加完整的日志了
grep: /home/lyf/work/sdk5.1.4/Linux_for_Tegra/bootloader/signed/flash.idx: No such file or directory
这是报的错误原因
