请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
[*] Jetson AGX Orin
Jetson 软件
JetPack 5.1.3
[*] JetPack 5.1.4
JetPack 6.0
JetPack 6.1
JetPack 6.2
DeepStream SDK
NVIDIA Isaac
问题描述
我在使用相机的驱动时候,相机驱动成功了也生成了对应的video节点,但是我发现max9295和9296的驱动日志出现了错误
错误日志
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000894] pid_max: default: 32768 minimum: 301
[ 0.260685] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.947715] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 7.908312] max9296 2-0048: [MAX9296]: probing GMSL Deserializer
[ 7.915441] max9295 2-0062: [MAX9295]: probing GMSL Serializer
[ 7.922295] max9295 2-0030: [MAX9295]: probing GMSL Serializer
[ 7.929157] max9295 2-0031: [MAX9295]: probing GMSL Serializer
[ 7.936003] max9296 2-004a: [MAX9296]: probing GMSL Deserializer
[ 7.942994] max9295 2-0063: [MAX9295]: probing GMSL Serializer
[ 7.949850] max9295 2-0032: [MAX9295]: probing GMSL Serializer
[ 7.956659] max9295 2-0033: [MAX9295]: probing GMSL Serializer
[ 7.963492] max9296 2-0068: [MAX9296]: probing GMSL Deserializer
[ 7.970500] max9295 2-0064: [MAX9295]: probing GMSL Serializer
[ 7.977301] max9295 2-0034: [MAX9295]: probing GMSL Serializer
[ 7.984134] max9295 2-0035: [MAX9295]: probing GMSL Serializer
[ 7.990988] max9296 2-006c: [MAX9296]: probing GMSL Deserializer
[ 7.997951] max9295 2-0065: [MAX9295]: probing GMSL Serializer
[ 8.004722] max9295 2-0036: [MAX9295]: probing GMSL Serializer
[ 8.011511] max9295 2-0037: [MAX9295]: probing GMSL Serializer
[ 9.335350] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.608718] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.076154] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 15.043406] cryptd: max_cpu_qlen set to 1000
[ 58.858179] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 12
[ 58.894369] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 12
[ 58.930463] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 12
[ 58.966407] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 12
[ 59.001878] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 2
[ 59.039810] max9296 2-006c: max9296_write_reg:i2c write failed, 0x10 = 1
[ 59.047244] max9296 2-006c: max9296_write_reg:i2c write failed, 0x10 = 21
[ 59.054893] max9296 2-006c: max9296_write_reg:i2c write failed, 0x313 = 0
[ 59.176386] max9295 2-0036: max9295_setup_control_enter
[ 59.176786] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 6c
[ 59.185111] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 6c
[ 59.193453] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 6c
[ 59.201860] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 6c
[ 59.210544] max9295 2-0036: max9295_write_reg:i2c write failed, dev:0x36, 0x10 = 21
[ 59.218597] max9295 2-0036: max9295_setup_control: ERROR: ser device not found
[ 59.232423] max9296 2-006c: max9296_write_reg:i2c write failed, 0x332 = f0
[ 59.257415] max9296 2-006c: max9296_write_reg:i2c write failed, 0x1 = 2
[ 59.295592] max9296 2-006c: max9296_write_reg:i2c write failed, 0x10 = 2
[ 59.303231] max9296 2-006c: max9296_write_reg:i2c write failed, 0x10 = 22
[ 59.310875] max9296 2-006c: max9296_write_reg:i2c write failed, 0x313 = 0
[ 59.433422] max9295 2-0037: max9295_setup_control_enter
[ 59.433827] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 6e
[ 59.442818] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 6e
[ 59.451264] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 6e
[ 59.459983] max9295 2-0065: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 6e
[ 59.468618] max9295 2-0037: max9295_write_reg:i2c write failed, dev:0x37, 0x10 = 22
[ 59.476658] max9295 2-0037: max9295_setup_control: ERROR: ser device not found
[ 59.490548] max9296 2-006c: max9296_write_reg:i2c write failed, 0x332 = f0
[ 59.534123] max9296 2-0068: max9296_write_reg:i2c write failed, 0x1 = 2
[ 59.573457] max9296 2-0068: max9296_write_reg:i2c write failed, 0x10 = 1
[ 59.580939] max9296 2-0068: max9296_write_reg:i2c write failed, 0x10 = 21
[ 59.588514] max9296 2-0068: max9296_write_reg:i2c write failed, 0x313 = 0
[ 59.708460] max9295 2-0034: max9295_setup_control_enter
[ 59.708879] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 68
[ 59.717276] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 68
[ 59.725636] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 68
[ 59.733970] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 68
[ 59.742334] max9295 2-0034: max9295_write_reg:i2c write failed, dev:0x34, 0x10 = 21
[ 59.750358] max9295 2-0034: max9295_setup_control: ERROR: ser device not found
[ 59.764291] max9296 2-0068: max9296_write_reg:i2c write failed, 0x332 = f0
[ 59.781555] max9296 2-0068: max9296_write_reg:i2c write failed, 0x1 = 2
[ 59.826288] max9296 2-0068: max9296_write_reg:i2c write failed, 0x10 = 2
[ 59.834001] max9296 2-0068: max9296_write_reg:i2c write failed, 0x10 = 22
[ 59.841593] max9296 2-0068: max9296_write_reg:i2c write failed, 0x313 = 0
[ 59.960648] max9295 2-0035: max9295_setup_control_enter
[ 59.961070] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 6a
[ 59.969580] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 6a
[ 59.977960] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 6a
[ 59.986558] max9295 2-0064: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 6a
[ 59.995129] max9295 2-0035: max9295_write_reg:i2c write failed, dev:0x35, 0x10 = 22
[ 60.003172] max9295 2-0035: max9295_setup_control: ERROR: ser device not found
[ 60.017327] max9296 2-0068: max9296_write_reg:i2c write failed, 0x332 = f0
[ 60.062180] max9296 2-004a: max9296_write_reg:i2c write failed, 0x1 = 2
[ 60.105370] max9296 2-004a: max9296_write_reg:i2c write failed, 0x10 = 1
[ 60.113184] max9296 2-004a: max9296_write_reg:i2c write failed, 0x10 = 21
[ 60.120997] max9296 2-004a: max9296_write_reg:i2c write failed, 0x313 = 0
[ 60.240753] max9295 2-0032: max9295_setup_control_enter
[ 60.241184] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 64
[ 60.250637] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 64
[ 60.259075] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 64
[ 60.267431] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 64
[ 60.275824] max9295 2-0032: max9295_write_reg:i2c write failed, dev:0x32, 0x10 = 21
[ 60.283885] max9295 2-0032: max9295_setup_control: ERROR: ser device not found
[ 60.297824] max9296 2-004a: max9296_write_reg:i2c write failed, 0x332 = f0
[ 60.314527] max9296 2-004a: max9296_write_reg:i2c write failed, 0x1 = 2
[ 60.358190] max9296 2-004a: max9296_write_reg:i2c write failed, 0x10 = 2
[ 60.365935] max9296 2-004a: max9296_write_reg:i2c write failed, 0x10 = 22
[ 60.373762] max9296 2-004a: max9296_write_reg:i2c write failed, 0x313 = 0
[ 60.494554] max9295 2-0033: max9295_setup_control_enter
[ 60.494996] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 66
[ 60.503467] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 66
[ 60.511846] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 66
[ 60.520254] max9295 2-0063: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 66
[ 60.529020] max9295 2-0033: max9295_write_reg:i2c write failed, dev:0x33, 0x10 = 22
[ 60.537090] max9295 2-0033: max9295_setup_control: ERROR: ser device not found
[ 60.551059] max9296 2-004a: max9296_write_reg:i2c write failed, 0x332 = f0
[ 60.597663] max9296 2-0048: max9296_write_reg:i2c write failed, 0x1 = 2
[ 60.637355] max9296 2-0048: max9296_write_reg:i2c write failed, 0x10 = 1
[ 60.644848] max9296 2-0048: max9296_write_reg:i2c write failed, 0x10 = 21
[ 60.652456] max9296 2-0048: max9296_write_reg:i2c write failed, 0x313 = 0
[ 60.774283] max9295 2-0030: max9295_setup_control_enter
[ 60.774693] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 60
[ 60.783077] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 60
[ 60.791433] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 60
[ 60.799864] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 60
[ 60.808243] max9295 2-0030: max9295_write_reg:i2c write failed, dev:0x30, 0x10 = 21
[ 60.816283] max9295 2-0030: max9295_setup_control: ERROR: ser device not found
[ 60.830246] max9296 2-0048: max9296_write_reg:i2c write failed, 0x332 = f0
[ 60.848078] max9296 2-0048: max9296_write_reg:i2c write failed, 0x1 = 2
[ 60.889732] max9296 2-0048: max9296_write_reg:i2c write failed, 0x10 = 2
[ 60.897195] max9296 2-0048: max9296_write_reg:i2c write failed, 0x10 = 22
[ 60.904788] max9296 2-0048: max9296_write_reg:i2c write failed, 0x313 = 0
[ 61.024498] max9295 2-0031: max9295_setup_control_enter
[ 61.024888] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x40, 0x0 = 62
[ 61.033926] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x42, 0x0 = 62
[ 61.042314] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x60, 0x0 = 62
[ 61.050767] max9295 2-0062: max9295_write_reg:i2c write failed, dev:0x62, 0x0 = 62
[ 61.059183] max9295 2-0031: max9295_write_reg:i2c write failed, dev:0x31, 0x10 = 22
[ 61.067210] max9295 2-0031: max9295_setup_control: ERROR: ser device not found
[ 61.081600] max9296 2-0048: max9296_write_reg:i2c write failed, 0x332 = f0
