请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson AGX Orin
[✓] Jetson Orin NX
Jetson Orin Nano
Jetson AGX Xavier
Jetson Xavier NX
Jetson TX 系列
Jetson Nano
Jetson 软件
JetPack 5.1.3
JetPack 5.1.4
JetPack 6.0
[✓] JetPack 6.1
DeepStream SDK
NVIDIA Isaac
SDK Manager 管理工具版本
[✓] 2.1.0
其他
问题描述
我使用sdk manager 自动安装后,最大功率只有25W,同时没有super模式。我查阅官方文档后发现应该使用指令模式,但是我在/nvidia/nvidia_sdk/Linux_for_Tegra 下运行命令,没有执行成功
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit-super internal
After using SDK Manager for automatic installation, the maximum power consumption is capped at 25W with no Super mode available. According to the official documentation, command-line flashing is required. However, when executing the command in /nvidia/nvidia_sdk/Linuxfor_Tegra , the process failed with the followingsudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit-super internal
错误码
错误提示/error:
###############################################################################L4T BSP Information:R36 , REVISION: 4.3User release: 0.0###############################################################################ECID isBoard ID() version() sku() revision()Preset RAMCODE isChip SKU(00:00:00:D3) ramcode() fuselevel(fuselevel_production) board_FAB()emc_opt_disable_fuse:(0)Error: Unrecognized module SKUError: failed to generate images
