请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson Orin Nano
Jetson 软件
JetPack 5.1.1
问题描述
Jetson Orin nano 在正常使用一段时间后,突然遇到无法正常进入ubuntu图形桌面系统情况。我们的使用场景是将Jetson Orin nano 集成到机器人系统框架上的。请问是机器人系统不合理的电源系统造成了nvme硬盘内部系统文件损坏?还是开发人员人为误操作导致的系统文件损坏?
错误日志
这是通过串口获取的boot up log:
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x15f4f9a98 SMBIOS=0xffff0000 SMBIOS 3.0=0x141310000 MEMATTR=0x13ffb2018 ESRT=0x1400a8218 RNG=0x164536c18 MEMRESERVE=0x13ffbcf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000001400a8218 to 0x00000001400a8250.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000154400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000016fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000013bffffff]
[ 0.000000] node 0: [mem 0x000000013c000000-0x000000013e1bffff]
[ 0.000000] node 0: [mem 0x000000013e1c0000-0x000000013ff4ffff]
[ 0.000000] node 0: [mem 0x000000013ff50000-0x000000013ff7ffff]
[ 0.000000] node 0: [mem 0x000000013ff80000-0x000000013ffbffff]
[ 0.000000] node 0: [mem 0x000000013ffc0000-0x000000014005ffff]
[ 0.000000] node 0: [mem 0x0000000140060000-0x000000014006ffff]
[ 0.000000] node 0: [mem 0x0000000140070000-0x000000014008ffff]
[ 0.000000] node 0: [mem 0x0000000140090000-0x0000000140e2afff]
[ 0.000000] node 0: [mem 0x0000000140e2b000-0x0000000140f8cfff]
[ 0.000000] node 0: [mem 0x0000000140f8d000-0x00000001412affff]
[ 0.000000] node 0: [mem 0x00000001412b0000-0x00000001412bffff]
[ 0.000000] node 0: [mem 0x00000001412c0000-0x000000014130ffff]
[ 0.000000] node 0: [mem 0x0000000141310000-0x000000014131ffff]
[ 0.000000] node 0: [mem 0x0000000141320000-0x000000014160ffff]
[ 0.000000] node 0: [mem 0x0000000141610000-0x000000014165ffff]
[ 0.000000] node 0: [mem 0x0000000141660000-0x000000014181ffff]
[ 0.000000] node 0: [mem 0x0000000141820000-0x00000001419fffff]
[ 0.000000] node 0: [mem 0x0000000141a00000-0x0000000141a8ffff]
[ 0.000000] node 0: [mem 0x0000000141a90000-0x0000000141c6ffff]
[ 0.000000] node 0: [mem 0x0000000141c70000-0x0000000141ccffff]
[ 0.000000] node 0: [mem 0x0000000141cd0000-0x0000000141dbffff]
[ 0.000000] node 0: [mem 0x0000000141dc0000-0x0000000141deffff]
[ 0.000000] node 0: [mem 0x0000000141df0000-0x0000000141dfffff]
[ 0.000000] node 0: [mem 0x0000000141e00000-0x0000000141eaffff]
[ 0.000000] node 0: [mem 0x0000000141eb0000-0x0000000141f4ffff]
[ 0.000000] node 0: [mem 0x0000000141f50000-0x000000014204ffff]
[ 0.000000] node 0: [mem 0x0000000142050000-0x00000001420effff]
[ 0.000000] node 0: [mem 0x00000001420f0000-0x00000001421effff]
[ 0.000000] node 0: [mem 0x00000001421f0000-0x000000014228ffff]
[ 0.000000] node 0: [mem 0x0000000142290000-0x0000000142b5ffff]
[ 0.000000] node 0: [mem 0x0000000142b60000-0x0000000142d3ffff]
[ 0.000000] node 0: [mem 0x0000000142d40000-0x00000001644effff]
[ 0.000000] node 0: [mem 0x00000001644f0000-0x000000016453ffff]
[ 0.000000] node 0: [mem 0x0000000164540000-0x0000000167ffffff]
[ 0.000000] node 0: [mem 0x0000000168200000-0x000000016860ffff]
[ 0.000000] node 0: [mem 0x000000016e000000-0x000000016fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000016fffffff]
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 944144
[ 0.000000] Kernel command line: root=PARTUUID=9e367c3f-a96f-456a-9996-d4cf40eb09d5 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 3114960K/3838016K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 460912K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000677] Console: colour dummy device 80x25
[ 0.000720] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000727] pid_max: default: 32768 minimum: 301
[ 0.000784] LSM: Security Framework initializing
[ 0.000806] Yama: becoming mindful.
[ 0.000824] SELinux: Initializing.
[ 0.000879] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000889] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001620] /cpus/cpu-map/cluster1: empty cluster
[ 0.001918] rcu: Hierarchical SRCU implementation.
[ 0.001998] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002361] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0004-p3768-0000-a0.dts
[ 0.002366] DTB Build time: Mar 19 2023 08:08:40
[ 0.003605] Tegra Revision: A01 SKU: 0xd6 CPU Process: 0 SoC Process: 0
[ 0.003769] Remapping and enabling EFI services.
[ 0.004974] smp: Bringing up secondary CPUs ...
[ 0.033664] Detected PIPT I-cache on CPU1
[ 0.033699] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033728] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062371] Detected PIPT I-cache on CPU2
[ 0.062381] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062396] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091002] Detected PIPT I-cache on CPU3
[ 0.091011] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091025] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.121680] Detected PIPT I-cache on CPU4
[ 0.121702] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.121732] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.150430] Detected PIPT I-cache on CPU5
[ 0.150442] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.150458] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.150520] smp: Brought up 1 node, 6 CPUs
[ 0.150534] SMP: Total of 6 processors activated.
[ 0.150538] CPU features: detected: Privileged Access Never
[ 0.150540] CPU features: detected: LSE atomic instructions
[ 0.150541] CPU features: detected: User Access Override
[ 0.150543] CPU features: detected: 32-bit EL0 Support
[ 0.150546] CPU features: detected: Common not Private translations
[ 0.150548] CPU features: detected: RAS Extension Support
[ 0.150549] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.150551] CPU features: detected: CRC32 instructions
[ 0.150553] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.187164] CPU: All CPU(s) started at EL2
[ 0.188851] devtmpfs: initialized
[ 0.205577] Registered cp15_barrier emulation handler
[ 0.205587] Registered setend emulation handler
[ 0.205592] KASLR enabled
[ 0.205733] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.205746] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.207431] pinctrl core: initialized pinctrl subsystem
[ 0.208011] SMBIOS 3.0.0 present.
[ 0.208020] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.208311] NET: Registered protocol family 16
[ 0.209190] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.209229] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.209259] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.209287] audit: initializing netlink subsys (disabled)
[ 0.209380] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1
[ 0.209567] thermal_sys: Registered thermal governor 'step_wise'
[ 0.209569] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.209572] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.210468] cpuidle: using governor menu
[ 0.210590] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.210666] ASID allocator initialised with 32768 entries
[ 0.210771] Serial: AMBA PL011 UART driver
[ 0.212703] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.212730] Tegra reboot handler registered.
[ 0.233593] mc: mapped MMIO address: 0xffff800010630000 -> 0x2c10000
[ 0.233606] mc: mapped MMIO address: 0xffff800010650000 -> 0x2c20000
[ 0.233616] mc: mapped MMIO address: 0xffff800010670000 -> 0x2c30000
[ 0.233625] mc: mapped MMIO address: 0xffff800010690000 -> 0x2c40000
[ 0.233634] mc: mapped MMIO address: 0xffff8000106b0000 -> 0x2c50000
[ 0.233642] mc: mapped MMIO address: 0xffff8000106d0000 -> 0x2b80000
[ 0.233650] mc: mapped MMIO address: 0xffff8000106f0000 -> 0x2b90000
[ 0.233657] mc: mapped MMIO address: 0xffff800010710000 -> 0x2ba0000
[ 0.233664] mc: mapped MMIO address: 0xffff800010730000 -> 0x2bb0000
[ 0.233670] mc: mapped MMIO address: 0xffff800010750000 -> 0x1700000
[ 0.233678] mc: mapped MMIO address: 0xffff800010770000 -> 0x1710000
[ 0.233685] mc: mapped MMIO address: 0xffff800010790000 -> 0x1720000
[ 0.233691] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x1730000
[ 0.233698] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x1740000
[ 0.233705] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x1750000
[ 0.233714] mc: mapped MMIO address: 0xffff800010810000 -> 0x1760000
[ 0.233720] mc: mapped MMIO address: 0xffff800010830000 -> 0x1770000
[ 0.233729] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.233751] mc-err: mcerr ops are set to t23x
[ 0.234500] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.401708] printk: console [ttyAMA0] enabled
[ 1.410438] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.417145] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.423844] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.430542] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.439203] ACPI: Interpreter disabled.
[ 1.443464] ddr-vddq: supplied by vdd-5v
[ 1.447577] ddr-vdd2: supplied by vdd-5v
[ 1.451624] vdd-AO-1v2: supplied by vdd-5v
[ 1.455843] vdd-3v3: supplied by vdd-5v
[ 1.459951] vdd-rtc: supplied by vdd-AO-1v2
[ 1.464264] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.469096] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.474071] vdd-1v8: supplied by vdd-3v3-sys
[ 1.478456] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.483017] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.487755] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.492306] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.496878] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.501681] iommu: Default domain type: Translated
[ 1.506593] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.512870] SCSI subsystem initialized
[ 1.516693] usbcore: registered new interface driver usbfs
[ 1.522189] usbcore: registered new interface driver hub
[ 1.527509] usbcore: registered new device driver usb
[ 1.532772] mc: Linux media interface: v0.10
[ 1.537046] videodev: Linux video capture interface: v2.00
[ 1.542702] pps_core: LinuxPPS API ver. 1 registered
[ 1.547664] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.556798] PTP clock support registered
[ 1.560965] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.568120] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.575799] Registered efivars operations
[ 1.580304] FPGA manager framework
[ 1.583740] Advanced Linux Sound Architecture Driver Initialized.
[ 1.590106] Bluetooth: Core ver 2.22
[ 1.593690] NET: Registered protocol family 31
[ 1.598131] Bluetooth: HCI device and connection manager initialized
[ 1.604488] Bluetooth: HCI socket layer initialized
[ 1.609364] Bluetooth: L2CAP socket layer initialized
[ 1.614418] Bluetooth: SCO socket layer initialized
[ 1.619878] camchar: rtcpu character device driver loaded
[ 1.625521] clocksource: Switched to clocksource arch_sys_counter
[ 1.824098] VFS: Disk quotas dquot_6.6.0
[ 1.828062] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.835093] pnp: PnP ACPI: disabled
[ 1.840730] la/ptsa driver initialized.
[ 1.844629] NET: Registered protocol family 2
[ 1.849090] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.857376] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 1.865920] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.873876] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.881451] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.888045] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.894761] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.901963] NET: Registered protocol family 1
[ 1.906532] RPC: Registered named UNIX socket transport module.
[ 1.912461] RPC: Registered udp transport module.
[ 1.917163] RPC: Registered tcp transport module.
[ 1.921864] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.928309] PCI: CLS 0 bytes, default 64
[ 1.932323] Trying to unpack rootfs image as initramfs...
[ 2.090139] Freeing initrd memory: 9120K
[ 2.096273] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.104208] kvm [1]: IPA Size Limit: 48 bits
[ 2.108532] kvm [1]: GICv3: no GICV resource entry
[ 2.113322] kvm [1]: disabling GICv2 emulation
[ 2.117781] kvm [1]: GIC system register CPU interface enabled
[ 2.123677] kvm [1]: vgic interrupt IRQ9
[ 2.127710] kvm [1]: VHE mode initialized successfully
[ 2.133553] Initialise system trusted keyrings
[ 2.138081] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 2.147121] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.153321] NFS: Registering the id_resolver key type
[ 2.158385] Key type id_resolver registered
[ 2.162567] Key type id_legacy registered
[ 2.166613] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.173321] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.180725] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.199240] NET: Registered protocol family 38
[ 2.203687] Key type asymmetric registered
[ 2.207780] Asymmetric key parser 'x509' registered
[ 2.212678] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.220134] io scheduler mq-deadline registered
[ 2.224666] io scheduler kyber registered
[ 2.233048] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.238653] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.244245] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.250685] efifb: probing for efifb
[ 2.254294] efifb: framebuffer at 0x13c000000, using 8640k, total 8640k
[ 2.260910] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[ 2.267001] efifb: scrolling: redraw
[ 2.270575] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.279877] Console: switching to colour frame buffer device 240x67
[ 2.289610] fb0: EFI VGA frame buffer device
[ 2.295805] tegra_dc_assign_hw_data: no matching compatible node
[ 2.301829] tegradccommon module_init failed
[ 2.306098] tegradc module_init failed
[ 2.310142] EINJ: ACPI disabled.
[ 2.315121] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.322002] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.327313] tegra-pmc: ### PMC reset level: L0
[ 2.331752] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.338161] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.354774] random: fast init done
[ 2.358810] printk: console [ttyTCU0] enabled
[ 3.982604] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.989313] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.994150] arm-smmu 12000000.iommu: stage 1 translation
[ 3.999716] arm-smmu 12000000.iommu: stage 2 translation
[ 4.005248] arm-smmu 12000000.iommu: nested translation
[ 4.010694] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.018097] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.027216] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.033910] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.040601] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.048137] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.054831] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.059648] arm-smmu 10000000.iommu: stage 1 translation
[ 4.065178] arm-smmu 10000000.iommu: stage 2 translation
[ 4.070709] arm-smmu 10000000.iommu: nested translation
[ 4.076161] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.083572] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.092663] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.099358] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.106055] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.113231] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.119838] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.124568] arm-smmu 8000000.iommu: stage 1 translation
[ 4.130010] arm-smmu 8000000.iommu: stage 2 translation
[ 4.135451] arm-smmu 8000000.iommu: nested translation
[ 4.140800] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.148122] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.157139] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.163743] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.170350] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.177661] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.187248] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.193212] tegra_profiler: auth: init
[ 4.197381] nvsciipc: loaded module
[ 4.202664] tun: Universal TUN/TAP device driver, 1.6
[ 4.208375] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.215789] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.221265] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.226349] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.232424] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.237963] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.243853] PPP generic driver version 2.4.2
[ 4.248280] PPP BSD Compression module registered
[ 4.253108] PPP Deflate Compression module registered
[ 4.258299] PPP MPPE Compression module registered
[ 4.263236] usbcore: registered new interface driver r8152
[ 4.268873] usbcore: registered new interface driver asix
[ 4.274412] usbcore: registered new interface driver ax88179_178a
[ 4.280677] usbcore: registered new interface driver cdc_ether
[ 4.286669] usbcore: registered new interface driver net1080
[ 4.292482] usbcore: registered new interface driver cdc_subset
[ 4.298554] usbcore: registered new interface driver zaurus
[ 4.304283] usbcore: registered new interface driver cdc_ncm
[ 4.310100] usbcore: registered new interface driver aqc111
[ 4.315935] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.322277] ohci-pci: OHCI PCI platform driver
[ 4.326843] ohci-platform: OHCI generic platform driver
[ 4.332555] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.338921] usbcore: registered new interface driver uas
[ 4.344400] usbcore: registered new interface driver usb-storage
[ 4.350735] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.356822] mousedev: PS/2 mouse device common for all mice
[ 4.362557] usbcore: registered new interface driver xpad
[ 4.370048] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.375510] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 4.383738] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.390138] i2c /dev entries driver
[ 4.393852] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.399652] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.405362] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.411036] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.416715] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.422393] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.428068] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.433740] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.443119] device-mapper: uevent: version 1.0.3
[ 4.447954] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.457676] sdhci: Secure Digital Host Controller Interface driver
[ 4.464016] sdhci: Copyright(c) Pierre Ossman
[ 4.468481] Synopsys Designware Multimedia Card Interface Driver
[ 4.474730] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.480929] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.481402] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.494299] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.502154] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.507742] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.522502] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.528454] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
Failed to create /rm/vdd_cpu
debugfs initialized
[ 6.926051] hid: raw HID events driver (C) Jiri Kosina
[ 6.931943] usbcore: registered new interface driver usbhid
[ 6.937679] usbhid: USB HID core driver
[ 6.942104] tegra-dce d800000.dce: Adding to iommu group 4
[ 6.949116] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 6.957712] tegra234-aon c000000.aon: Adding to iommu group 5
[ 6.964340] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.966350] c000000.aon:hsp: probed
[ 6.973311] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.985751] tegra234-aon c000000.aon: init done
[ 6.986185] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 6.990433] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.996653] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 7.003329] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 7.009651] tegra23x-psc e860000.psc: init done
[ 7.018604] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 7.018605] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 7.018615] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 7.023486] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 7.031655] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 7.031784] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 7.041105] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 7.049188] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 7.049189] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 7.049199] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 7.058212] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 7.063553] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 7.072312] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 7.132633] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 7.144102] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 7.155853] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 7.168418] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 7.181233] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 7.193295] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 7.200091] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.209063] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 7.222670] t19x_cache tegra-cache: probed
[ 7.227122] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 7.237348] optee: probing for conduit method.
[ 7.241937] optee: revision 3.19 (3f29c61f)
[ 7.242737] optee: dynamic shared memory is enabled
[ 7.252171] optee: initialized driver
[ 7.267478] nvpmodel: initialized successfully
[ 7.272154] tegra_hv: get_hvd: not initialized yet
[ 7.277087] user_ivc_mempool: hypervisor not present
[ 7.282976] usbcore: registered new interface driver snd-usb-audio
[ 7.290166] u32 classifier
[ 7.292943] input device check on
[ 7.296713] Actions configured
[ 7.300343] Initializing XFRM netlink socket
[ 7.305271] NET: Registered protocol family 10
[ 7.310790] Segment Routing with IPv6
[ 7.314611] NET: Registered protocol family 17
[ 7.319192] NET: Registered protocol family 15
[ 7.323811] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.337840] Bluetooth: RFCOMM socket layer initialized
[ 7.343138] Bluetooth: RFCOMM ver 1.11
[ 7.346993] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.353082] Bluetooth: HIDP socket layer initialized
[ 7.358501] 9pnet: Installing 9P2000 support
[ 7.362953] Key type dns_resolver registered
[ 7.368082] registered taskstats version 1
[ 7.372299] Loading compiled-in X.509 certificates
[ 7.386906] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 7.397653] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 7.410707] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.418018] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 7.430544] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.437530] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 7.449779] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 7.456676] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 7.469260] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.502965] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 7.513762] host1x 13e40000.host1x: Adding to iommu group 13
[ 7.549117] host1x 13e40000.host1x: initialized
[ 7.554216] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 7.562263] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.574551] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 7.582531] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.594792] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 7.602792] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.615078] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 7.623102] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.635370] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 7.643343] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.655591] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 7.663561] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.675838] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 7.683814] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.696063] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 7.704033] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.716310] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 7.724307] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.736577] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 7.744545] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.756816] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 7.764825] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.777088] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 7.785056] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.797294] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 7.805264] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.817539] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 7.825524] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.837764] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 7.845748] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.858029] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 7.866009] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.878289] falcon 15340000.vic: Adding to iommu group 30
[ 7.889034] falcon 15340000.vic: initialized
[ 7.893774] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.902782] falcon 15380000.nvjpg: initialized
[ 7.907493] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.917102] falcon 15540000.nvjpg1: initialized
[ 7.921923] falcon 15a50000.ofa: Adding to iommu group 33
[ 7.930895] falcon 15a50000.ofa: initialized
[ 7.935459] nvdec 15480000.nvdec: Adding to iommu group 34
[ 7.947599] nvdec 15480000.nvdec: initialized
[ 7.952229] tsec 15500000.tsec: Adding to iommu group 35
[ 7.962289] tsec 15500000.tsec: initialized
[ 7.969644] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.987289] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 8.003093] gpio-397 (camera-control-output-low): hogged as output/low
[ 8.009841] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.017648] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.024982] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.031971] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.038474] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.044906] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.053180] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 8.061718] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.071000] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.077456] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 8.086674] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 8.095839] random: crng init done
[ 8.096043] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 8.107469] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 8.115416] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.125388] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.132188] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.142173] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.148975] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.158974] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.165888] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 8.173007] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.180514] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.187135] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.193853] serial-tegra 3100000.serial: Adding to iommu group 2
[ 8.200467] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 8.210412] serial-tegra 3130000.serial: Adding to iommu group 2
[ 8.216966] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 8.226667] serial-tegra 3140000.serial: Adding to iommu group 2
[ 8.233168] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 8.259555] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.269304] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.274870] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.283533] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.293141] tegra-xusb 3610000.xhci: irq 219, io mem 0x03610000
[ 8.299570] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.308072] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.315498] usb usb1: Product: xHCI Host Controller
[ 8.320503] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.326758] usb usb1: SerialNumber: 3610000.xhci
[ 8.332274] hub 1-0:1.0: USB hub found
[ 8.336156] hub 1-0:1.0: 4 ports detected
[ 8.340527] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.346086] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.353873] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.361381] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.369884] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.377312] usb usb2: Product: xHCI Host Controller
[ 8.382316] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.388574] usb usb2: SerialNumber: 3610000.xhci
[ 8.393851] hub 2-0:1.0: USB hub found
[ 8.397719] hub 2-0:1.0: 4 ports detected
[ 8.421098] i2c i2c-2: Added multiplexed i2c bus 9
[ 8.426390] i2c i2c-2: Added multiplexed i2c bus 10
[ 8.431418] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 8.438413] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 8.458079] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1581000 KHz, changing to: 1510400 KHz
[ 8.471714] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1583000 KHz, changing to: 1510400 KHz
[ 8.483624] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 8.491038] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.492713] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.498603] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.509600] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 8.511912] irq: IRQ283: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.518290] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 8.525982] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 8.534593] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.601535] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.657530] tegra194-pcie 14100000.pcie: Link up
[ 8.665217] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.672033] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.677684] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.687517] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.698339] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.706274] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.712617] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.724018] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.730356] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.736288] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.744766] pci 0001:01:00.0: supports D1 D2
[ 8.749160] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.761458] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.768888] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.775240] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.781772] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 8.783222] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.791571] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.797857] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.805183] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 8.810550] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.815304] usb 1-2: Manufacturer: Generic
[ 8.821597] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.828681] hub 1-2:1.0: USB hub found
[ 8.833155] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.838304] hub 1-2:1.0: 4 ports detected
[ 8.845768] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.858891] pcieport 0001:00:00.0: Adding to iommu group 8
[ 8.864828] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 8.871082] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 8.878051] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.886097] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.893267] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.898312] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.901949] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.918404] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.948580] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[ 8.956993] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.964334] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 8.969076] usb 2-1: Manufacturer: Generic
[ 8.982100] hub 2-1:1.0: USB hub found
[ 8.987640] hub 2-1:1.0: 4 ports detected
[ 9.033527] tegra194-pcie 14160000.pcie: Link up
[ 9.046022] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.052839] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.052842] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.052845] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.052846] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.052891] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.065754] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 9.068747] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.110908] pci 0004:01:00.0: [1ed0:2283] type 00 class 0x010802
[ 9.117265] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 9.124545] pci 0004:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 9.132558] pci 0004:01:00.0: reg 0x164: [mem 0x00000000-0x00003fff 64bit]
[ 9.139634] pci 0004:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0003ffff 64bit] (contains BAR0 for 16 VFs)
[ 9.155481] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 9.162913] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242800ffff pref]
[ 9.170700] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428010000-0x2428013fff 64bit]
[ 9.178665] pci 0004:01:00.0: BAR 7: assigned [mem 0x2428014000-0x2428053fff 64bit]
[ 9.186579] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.191955] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 9.199313] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.208056] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 9.217023] pcieport 0004:00:00.0: Adding to iommu group 9
[ 9.222915] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 9.229121] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 9.229687] usb 1-3: New USB device found, idVendor=0bda, idProduct=c822, bcdDevice= 0.00
[ 9.235198] nvme 0004:01:00.0: Adding to iommu group 9
[ 9.243265] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.243267] usb 1-3: Product: Bluetooth Radio
[ 9.243268] usb 1-3: Manufacturer: Realtek
[ 9.243270] usb 1-3: SerialNumber: 00e04c000001
[ 9.269905] nvme nvme0: pci function 0004:01:00.0
[ 9.274800] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 9.280759] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 9.288253] nvme nvme0: missing or invalid SUBNQN field.
[ 9.294183] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 9.301370] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 9.310055] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 9.318744] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 9.321540] nvme nvme0: allocated 128 MiB host memory buffer.
[ 9.338971] nvme nvme0: 6/0/0 default/read/poll queues
[ 9.345527] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 9.561529] usb 1-2.3: new high-speed USB device number 4 using tegra-xusb
[ 9.676976] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 9.685566] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.693077] usb 1-2.3: Product: USB2.1 Hub
[ 9.697298] usb 1-2.3: Manufacturer: GenesysLogic
[ 9.704149] hub 1-2.3:1.0: USB hub found
[ 9.708924] hub 1-2.3:1.0: 4 ports detected
[ 9.770195] usb 2-1.3: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 9.807185] usb 2-1.3: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 9.815769] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.823294] usb 2-1.3: Product: USB3.1 Hub
[ 9.827495] usb 2-1.3: Manufacturer: GenesysLogic
[ 9.841204] hub 2-1.3:1.0: USB hub found
[ 9.847374] hub 2-1.3:1.0: 4 ports detected
[ 10.033521] usb 1-2.3.1: new full-speed USB device number 5 using tegra-xusb
[ 10.175394] usb 1-2.3.1: New USB device found, idVendor=062a, idProduct=4101, bcdDevice= 1.17
[ 10.184166] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.191866] usb 1-2.3.1: Product: 2.4G Keyboard Mouse
[ 10.197057] usb 1-2.3.1: Manufacturer: MOSART Semi.
[ 10.208387] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.0/0003:062A:4101.0001/input/input0
[ 10.282114] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.3.1/input0
[ 10.299901] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.1/0003:062A:4101.0002/input/input1
[ 10.314698] input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.1/0003:062A:4101.0002/input/input2
[ 10.389966] input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.1/0003:062A:4101.0002/input/input3
[ 10.405758] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.1/0003:062A:4101.0002/input/input4
[ 10.420563] hid-generic 0003:062A:4101.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.3.1/input1
[ 10.425881] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 10.441126] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 10.447925] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 10.453563] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 10.463657] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.474481] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 10.482391] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.488713] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 10.503743] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 10.509135] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.518128] pcieport 0007:00:00.0: Adding to iommu group 10
[ 10.524109] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 10.530348] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 10.536325] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 10.537688] usb 1-2.3.3: new full-speed USB device number 6 using tegra-xusb
[ 10.542428] pci 0007:00:00.0: Removing from iommu group 10
[ 10.555213] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 10.562974] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.569806] vdd-3v3-sd: supplied by vdd-3v3
[ 10.576218] tegra194-isp5 14800000.isp: initialized
[ 10.586322] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.592776] (NULL device *): fops function table already registered
[ 10.600454] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.607499] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.607709] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.614341] irq: IRQ291: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.629557] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 10.682096] usb 1-2.3.3: New USB device found, idVendor=1ea7, idProduct=0066, bcdDevice= 2.00
[ 10.690864] usb 1-2.3.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 10.698561] usb 1-2.3.3: Product: 2.4G Mouse
[ 10.709862] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.0/0003:1EA7:0066.0003/input/input5
[ 10.734465] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.741639] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 10.750330] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 10.759011] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 10.782087] hid-generic 0003:1EA7:0066.0003: input,hidraw2: USB HID v1.10 Keyboard [2.4G Mouse] on usb-3610000.xhci-2.3.3/input0
[ 10.799403] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:1EA7:0066.0004/input/input6
[ 10.811824] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:1EA7:0066.0004/input/input7
[ 10.824610] input: 2.4G Mouse Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:1EA7:0066.0004/input/input8
[ 10.873682] tegra194-pcie 140a0000.pcie: Link up
[ 10.880697] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.887510] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.893160] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.897963] input: 2.4G Mouse System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:1EA7:0066.0004/input/input9
[ 10.903279] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.903282] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.917760] hid-generic 0003:1EA7:0066.0004: input,hiddev97,hidraw3: USB HID v1.10 Mouse [2.4G Mouse] on usb-3610000.xhci-2.3.3/input1
[ 10.927643] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.954197] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.964839] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.971162] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.977075] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.984171] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.992187] pci 0008:01:00.0: supports D1 D2
[ 10.996585] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 11.008594] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 11.016030] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 11.022736] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 11.030698] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 11.038659] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 11.045316] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 11.050684] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 11.057314] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 11.064681] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 11.073419] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 11.082393] pcieport 0008:00:00.0: Adding to iommu group 11
[ 11.088381] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 11.094571] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 11.101746] irq: IRQ293: trimming hierarchy from :pmc@c360000
[ 11.107729] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.115440] input: gpio-keys as /devices/platform/gpio-keys/input/input11
[ 11.123275] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[ 11.129889] tegra-se-nvhost 15810000.se: initialized
[ 11.136491] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.142904] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[ 11.149478] tegra-se-nvhost 15820000.se: initialized
[ 11.155828] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.162233] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[ 11.168824] tegra-se-nvhost 15840000.se: initialized
[ 11.175615] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.182648] tegra_actmon d230000.actmon: in actmon_register()...
[ 11.189004] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.195053] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.203480] hvc_sysfs: hypervisor is not present
[ 11.244396] ALSA device list:
[ 11.247451] No soundcards found.
[ 11.251833] Freeing unused kernel memory: 3968K
[ 11.256592] Run /init as init process
[ 11.276621] Root device found: PARTUUID=9e367c3f-a96f-456a-9996-d4cf40eb09d5
[ 11.592561] EXT4-fs (nvme0n1p1): warning: mounting fs with errors, running e2fsck is recommended
[ 11.603782] EXT4-fs (nvme0n1p1): Errors on filesystem, clearing orphan list.
[ 11.603782]
[ 11.612552] EXT4-fs (nvme0n1p1): recovery complete
[ 11.617760] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.629910] Rootfs mounted over PARTUUID=9e367c3f-a96f-456a-9996-d4cf40eb09d5
[ 11.659959] Switching from initrd to actual rootfs
[ 11.680461] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.849788] systemd[1]: System time before build time, advancing clock.
[ 11.927830] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.951598] systemd[1]: Detected architecture arm64.
[ 11.997727] systemd[1]: Set hostname to <elephant-desktop>.
[ 12.211639] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.224667] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.234704] systemd[1]: Created slice system-modprobe.slice.
[ 12.254037] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.273971] systemd[1]: Created slice User and Session Slice.
[ 12.293643] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.317874] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.341622] systemd[1]: Reached target User and Group Name Lookups.
[ 12.361563] systemd[1]: Reached target Slices.
[ 12.377552] systemd[1]: Reached target Mounting snaps.
[ 12.397548] systemd[1]: Reached target Mounted snaps.
[ 12.417867] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.437695] systemd[1]: Listening on Syslog Socket.
[ 12.457686] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.481625] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.501821] systemd[1]: Listening on Journal Audit Socket.
[ 12.521677] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.541951] systemd[1]: Listening on Journal Socket.
[ 12.565716] systemd[1]: Listening on udev Control Socket.
[ 12.585641] systemd[1]: Listening on udev Kernel Socket.
[ 12.611151] systemd[1]: Mounting Huge Pages File System...
[ 12.631048] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.658929] systemd[1]: Mounting RPC Pipe File System...
[ 12.678964] systemd[1]: Mounting Kernel Debug File System...
[ 12.703054] systemd[1]: Mounting Kernel Trace File System...
[ 12.723239] systemd[1]: Starting Journal Service...
[ 12.747310] systemd[1]: Starting Set the console keyboard layout...
[ 12.775369] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.803073] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.829632] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.839459] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.858828] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.878906] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.899049] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.922967] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.950987] systemd[1]: Started Nameserver information manager.
[ 12.973794] systemd[1]: Reached target Network (Pre).
[ 12.998024] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.007384] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.023919] systemd[1]: Starting Load Kernel Modules...
[ 13.043034] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.051326] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.054343] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 13.060429] nvmap_page_pool_init: Total RAM pages: 847548
[ 13.073763] nvmap_page_pool_init: nvmap page pool size: 105943 pages (413 MB)
[ 13.081180] nvmap_background_zero_thread: PP zeroing thread starting.
[ 13.095529] systemd[1]: Starting udev Coldplug all Devices...
[ 13.115989] systemd[1]: Starting Uncomplicated firewall...
[ 13.129063] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 13.129063]
[ 13.156152] systemd[1]: Started Journal Service.
[ 13.485564] Adding 16777212k swap on /swapfile. Priority:-2 extents:63 across:247857152k SS
[ 13.498424] systemd-journald[239]: Received client request to flush runtime journal.
[ 14.154624] nvidia: loading out-of-tree module taints kernel.
[ 14.190121] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 14.206519] imx219 9-0010: board setup failed
[ 14.212103] imx219: probe of 9-0010 failed with error -121
[ 14.229436] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 14.244357] imx219 10-0010: board setup failed
[ 14.262193] imx219: probe of 10-0010 failed with error -121
[ 14.355080] fusb301 1-0025: toggle_time(0) is not updated
[ 15.078971] using random self ethernet address
[ 15.083845] using random host ethernet address
[ 15.560951] using random self ethernet address
[ 15.565645] using random host ethernet address
[ 18.136916] blk_update_request: critical medium error, dev nvme0n1, sector 94207944 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[ 18.161938] blk_update_request: critical medium error, dev nvme0n1, sector 94207592 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 18.182980] blk_update_request: critical medium error, dev nvme0n1, sector 94207616 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 18.198480] blk_update_request: critical medium error, dev nvme0n1, sector 94207616 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 18.822064] Bridge firewalling registered
Ubuntu 20.04.5 LTS elephant-desktop ttyTCU0 elephant-desktop login: elephant
[ 147.564855] blk_update_request: critical medium error, dev nvme0n1, sector 94207616 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 147.580051] blk_update_request: critical medium error, dev nvme0n1, sector 94207616 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Ubuntu 20.04.5 LTS elephant-desktop ttyTCU0 elephant-desktop login: [ 316.861542] EXT4-fs (nvme0n1p1): error count since last fsck: 53
[ 316.867777] EXT4-fs (nvme0n1p1): initial error at time 1755507870: __ext4_get_inode_loc_noinmem:4456: inode 3540729: block 14155903
[ 316.879970] EXT4-fs (nvme0n1p1): last error at time 1765794036: __ext4_get_inode_loc_noinmem:4456: inode 6430304: block 25690629
