jetson nano 适配ubuntu20.04问题
Jetson 模组
Jetson Nano
Jetson 软件
JetPack 4.6.1
SDK Manager 管理工具版本
1.9.3
问题描述
使用sdkmanager给jetson nano(P3448-0002) 16GB EMMC版本,刷写了ubuntu 18.04系统,再手动更新到ubuntu 20.04后,出现了内核的报错,请问我如何解决?
错误日志
[12.243425]Unable to handle kernel paging request at virtual address dead000000000160
[12.251539]Mem abort info:
[12.254393]ESR = 0x96000004
[12.257674]Exception class =DABT(current EL),IL =32 bits
[12.263853]SET =0,FnV =0
[12.267038]EA=0,S1PT =0
[12.270296]Data abort info:
[12.273385]ISV=0,ISS =0x00000004
[12.277333]CM =0,WnR =0
[12.280343] [dead000000000160] address between user and kernel address ranges
[12.287531] Internal error:0ops:96000004【#1]PREEMPT SMP
[12.293125]Modules linked in : userspace_alert binfmt_misc nvgpu ip_tables x_tables
[12.300874]CPU: 3 PID:1734 Com:kworker/3:2 Not tainted 4.9.253-tegra #1
[12.307861]Hardware name:NVIDIA Jetson Nano Deveioper Kit(DT)
[12.313897]Workgueue: events reed ta handlen
[12.318277]task: ffffffcof789f000 task.stack: ffffffc0f4c14000
[12.324220]PC is at__ll_sc__atomic_sub+0x4/0x18
[12.328855]LR is at sauashfs bh to actor+0x1d8/0x200
[12.333922]pc:[ffffff800845684c>]	lr:[<ffffff8008367790>] pstate: 20400045
[12.341342]sp :ffffffc0f4c17c60
[12.344665]x29:ffffffc0f4c17c60 		x28:0000000000000000
[12.350013]x27:00000000000001ba 	x26:0000000000000000
[12.355360]x25:0000000000000000 	x24:0000000000000000
[12.360706]x23:ffffffc0e3494400 		x22:ffffffc0f293f900
[12.366051]x21:0000000000000074 	x20:0000000000000000
[12.371398]x19:0000000000000074 	x18:0000000000000000
[12.376746]x17:0000000009ea2947 	x16:0000000000000000
[12.382092]x15:0000000000000196 	x14:0000000000013bd0
[12.387438]x13:000000000001a306 	x12:0000000000000400
[12.398133]x11:0000000000000400 	x10:0000000000000a10
[12.398133]x9:ffffffc0f4c17d10 		x8:ffffffc0f789fa70
[12.403481]x7:0000000000000400 	x6:0000000000000400
[12.408327]x5:0000000000000400 	x4:0000000000000004
[12.414175]x3:0000000000000002 	x2:0000000000000100
[12.419521]x1:dead000000000160 	x0:0000000000000001
[12.429855]
[12.426383]Process kworker/3:2(pid: 1446,stack limit = 0xffffffc0f4c14000)
[12.433521]Call trace:
[12.435976][<ffffff800845684c>]	__ll_sc_atomic_sub+0x4/0x18
[12.443220][<ffffff8008362708>]	squashfs_process_blocks+0x2c8/0x388
[12.451183][<ffffff80083627e8>]	read_wq_handler+0x20/0x30
[12.458293][<ffffff80080d40ac>]	process_one_work+0x1e4/0x4b0
[12.465680][<ffffff80080d43c8>]	worker_thread+0x50/0x4c8
[12.472738][<ffffff80080db09c>]	kthread+oxec/0xf0
[12.479170][<ffffff80080838a0>]	ret_from_fork+0x10/0x30
[12.486110]	---[ end trace 49e39e104c341bc6 ]---
[12.499395]Unable to handle kernel paging request at virtual address ffffffffffffffd8
[12.508977]Mem abort info:
[12.513398]ESR = 0x96000005
[12.518070]Exception class =DABT (current EL),IL =32 bits
[12.525617]	SET =0,FnV =0
[12.530289]	EA=0,S1PT =0
[12.535024]Data abort info:
[12.539493]	ISV=0,ISS =0x00000005
[12.544907]	CM =0,WnR =0
[12.549439]swapper pgtable:4k pages,39-bit WAs,pgd =ffffff800a200000
[12.557818] [ffffffffffffffd8] *pgd=0000000000000000,*pud=0000000000000000
[12.566400] Internal error:0ops:96000005【#1]PREEMPT SMP
[12.573573]Modules linked in : userspace_alert binfmt_misc nvgpu ip_tables x_tables
[12.582917]CPU: 3 PID:1446 Comm:kworker/3:2 Tainted: G	D		 	4.9.253-tegra #1
[12.592728]Hardware name:NVIDIA Jetson Nano Deveioper Kit(DT)
[12.600388]task: ffffffcof789f000 task.stack: ffffffc0f4c14000
[12.607961]PC is at_kthread_data+0x24/0x30
[12.613783]LR is at wq_worker_sleeping+0x20/0xd0
[12.620117]pc:[ffffff800845684c>]	lr:[<ffffff8008367790>] pstate: 804000c5
[12.629156]sp :ffffffc0f4c17890
[12.634122]x29:ffffffc0f4c17890 		x28:ffffffc0f789f000
[12.641092]x27:ffffffc0fa6f0000 		x26:0000000000000000
[12.648038]x25:ffffff80080eaf14 		x24:ffffffc0feffed80
[12.654988]x23:ffffffc0e3494400 		x22:ffffff8009836000
[12.661929]x21:ffffff8009e88000		x20:ffffff8009842000
[12.668856]x19:ffffffc0f789f000		x18:00000000fffffff6
[12.675791]x17:0000000009ea2947 	x16:0000000000000000
[12.682728]x15:0000000000000007  	x14:0000000000000001
[12.689655]x13:0000000000000019  	x12:0000000000000033
[12.696579]x11:000000000000004c 	x10:000000000000019
[12.703473]x9:0000000000000000 	x8:0000000002d8226b
[12.710348]x7:0000000000000000 	x6:0000000000000400
[12.717193]x5:0000000000006400 	x4:0000000002d8226b
[12.724012]x3:0000000000000002 	x2:000000073a2400a0
[12.730809]x1:ffffffc0feffed80 		x0:0000000000000000
[12.737590]
[12.740520]Process kworker/3:2(pid: 1446,stack limit = 0xffffffc0f4c14000)
[12.749111]Call trace:
[12.753021][<ffffff80080dbc94>] 	kthread_data+0x24/0x30
[12.759700][<ffffff8008f68220>] 	__schedule+0x3e0/0x7d0
[12.766374][<ffffff80080eaf14>] 	do_task_dead+0x74/0x78
[12.773044][<ffffff80080b8838>] 	do_exit+0x710/0xa88
[12.779453][<ffffff800808c1a4>] 	die+0x194/0x198
[12.785526][<ffffff80080a206c>] 	__do_kernel_fault+0x144/0x218
[12.792814][<ffffff80080a2184>]	do_bad _area+0x44/0x90
[12.799410][<ffffff80080a26ec>]	do_translation_fault+0x54/0x80
[12.806802][<ffffff8008080954>]	do_mem_abort+0x54/0xb0
[12.813507][<ffffff8008082904>]	el1 _da+0x24/0xbc
[12.819696][<ffffff8008362708>]	squashfs_process_blocks+0x2c8/0x388
[12.827552][<ffffff80083627e8>]	read_wq_handler+0x20/0x30
[12.834548][<ffffff80080d40ac>]	process_one_work+0x1e4/0x4b0
[12.841807][<ffffff80080d43c8>]	worker_thread+0x50/0x4c8
[12.848714][<ffffff80080db09c>]	kthread+oxec/0xf0
[12.855018][<ffffff80080838a0>]	ret_from_fork+0x10/0x30
[12.861857]	---[ end trace 49e39e104c341bc7 ]---
[12.875209]	note: kworkde/3:2[1446]	exited with preempt_count 2
[12.882680]	Fixing recursive fault but reboot is needed!
Jetson Nano 官方支持的是 “L4T + Ubuntu 18.04” 这一整套固件;内核、bootloader、驱动、rootfs 是一起发布和测试的,并不是任意 Ubuntu 版本都兼容。
直接对这个环境执行 do-release-upgrade 升到 20.04,会把大量核心包(systemd、glibc、工具链、压缩/文件系统相关库等)升级,但仍保留旧版 4.9.253‑tegra 内核和 NVIDIA 自定义模块,导致内核在处理 squashfs 读任务时出现非法地址访问
不建议手动更新到系统到 20.04
明白,感谢你的回复。
