Jetson AGX 开发板 去除RTS5420 HUB芯片 USB host功能失效
Jetson 模组
Jetson AGX Orin
Jetson Orin NX
Jetson 软件
JetPack 5.1.3
问题描述
基于英伟达NX载板,实际验证去掉RTS5420 HUB芯片,作为device设备可以被电脑识别端口正常加载,但是作为host设备无法识别外接设备(如U盘等外设)
错误码
把这里替换为错误码(无需其他信息)
错误日志
[ 14.026726] fusb301 1-0025: fusb301_work_handler: int_sts[0x01]
[ 14.027304] fusb301 1-0025: sts[0x21], type[0x10]
[ 14.028192] fusb301 1-0025: fusb301_set_dfp_power: host current(1)
[ 14.028198] fusb301 1-0025: fusb_update_state: 7
[ 14.028287] tegra-xusb 3610000.usb: xHCI host controller not responding, assume dead
[ 14.028291] tegra-xusb 3610000.usb: HC died; cleaning up
[ 14.028291] CPU:0, Error: cbb-fabric@0x13a00000, irq=179
[ 14.028298] **************************************
[ 14.028300] CPU:0, Error:cbb-fabric, Errmon:2
[ 14.028302] tegra-xusb 3610000.usb: HCD shut down
[ 14.028306] Error Code : PWRDOWN_ERR
[ 14.028317] Error Code : PWRDOWN_ERR
[ 14.028319] MASTER_ID : CCPLEX
[ 14.028321] Address : 0x3610430
[ 14.028323] Cache : 0x1 – Bufferable
[ 14.028326] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 14.028328] Access_Type : Read
[ 14.028329] Access_ID : 0x14
[ 14.028330] Fabric : cbb-fabric
[ 14.028331] Slave_Id : 0x22
[ 14.028332] Burst_length : 0x0
[ 14.028332] Burst_type : 0x1
[ 14.028333] Beat_size : 0x2
[ 14.028334] VQC : 0x0
[ 14.028334] GRPSEC : 0x7e
[ 14.028335] FALCONSEC : 0x0
[ 14.028336] Slave : AXI2APB_16
[ 14.028338] **************************************
[ 14.028344] tegra-xusb 3610000.usb: HCD shut down
[ 14.028359] ------------[ cut here ]------------
[ 14.028360] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x14c/0x180
[ 14.028373] Modules linked in:
[ 14.028373] tegra-xusb 3610000.usb: HCD shut down
[ 14.028375] bridge stp llc usb_f_ncm usb_f_mass_storage snd_soc_tegra210_ope(O) snd_soc_tegra186_asrc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_admaif(O) snd_soc_tegra210_mvc(O) snd_soc_tegra210)
[ 14.028402] tegra-xusb 3610000.usb: HCD shut down
[ 14.028403] snd_soc_tegra_machine_driver(O) snd_soc_tegra_utils(O) snd_soc_simple_card_utils crct10dif_ce tegra234_oc_event(O) nvpmodel_clk_cap(O) thermal_trip_event(O) mttcan(O) nvpps(O) fusb301(O)
[ 14.028433] tegra-xusb 3610000.usb: HCD shut down
[ 14.028434] nvhost_isp5(O) nvhost_nvcsi_t194(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ex)
[ 14.028461] tegra-xusb 3610000.usb: HCD shut down
[ 14.028461] drm_kms_helper nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) fuse drm ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal te4
[ 14.028487] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 5.15.136-tegra #1
[ 14.028490] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[ 14.028490] tegra-xusb 3610000.usb: HCD shut down
[ 14.028492] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 14.028495] pc : tegra234_cbb_isr+0x14c/0x180
[ 14.028496] lr : tegra234_cbb_isr+0x11c/0x180
[ 14.028498] sp : ffff800008003e60
[ 14.028499] x29: ffff800008003e60 x28: ffffc84872e42ec0 x27: 0000000000000001
[ 14.028501] x26: 00000000000000c0 x25: ffffc848724d6e80 x24: ffffc8487328b4c8
[ 14.028503] x23: ffffc8487282b008 x22: 00000000000000b3 x21: ffffc8487311e4d8
[ 14.028505] x20: 0000000000000000 x19: ffffc8487311e598 x18: ffffffffffffffff
[ 14.028507] x17: ffff37bb7d9c8000 x16: ffffc8487130f580 x15: ffffc8487324620f
[ 14.028509] x14: 0000000000000001 x13: 2a2a2a2a2a2a2a2a x12: 2a2a2a2a2a2a2a2a
[ 14.028511] x11: 2a2a2a2a2a2a2a2a x10: 2a2a2a2a2a2a2a2a x9 : 2a2a2a2a2a2a2a2a
[ 14.028513] x8 : 2a2a2a2a2a2a2a2a x7 : 2a2a2a2a2a2a2a2a x6 : 2a2a2a2a2a2a2a09
[ 14.028515] x5 : ffff0003f01f59f0 x4 : 00000000fffff302 x3 : 0000000000000000
[ 14.028517] x2 : ffffc848709c34f8 x1 : ffffc84872e42ec0 x0 : 0000000100010001
[ 14.028519] Call trace:
[ 14.028519] tegra-xusb 3610000.usb: HCD shut down
[ 14.028521] tegra234_cbb_isr+0x14c/0x180
[ 14.028523] __handle_irq_event_percpu+0x68/0x260
[ 14.028528] handle_irq_event+0x70/0x110
[ 14.028529] handle_fasteoi_irq+0xb0/0x1d0
[ 14.028532] handle_domain_irq+0x74/0xc0
[ 14.028536] gic_handle_irq+0x68/0x170
[ 14.028541] call_on_irq_stack+0x20/0x50
[ 14.028545] do_interrupt_handler+0x78/0xa0
[ 14.028548] tegra-xusb 3610000.usb: HCD shut down
[ 14.028548] el1_interrupt+0x30/0x70
[ 14.028554] el1h_64_irq_handler+0x18/0x30
[ 14.028555] el1h_64_irq+0x7c/0x80
[ 14.028557] cpuidle_enter_state+0xbc/0x3e0
[ 14.028562] cpuidle_enter+0x44/0x70
[ 14.028564] do_idle+0x228/0x2b0
[ 14.028567] cpu_startup_entry+0x34/0x70
[ 14.028569] rest_init+0xf0/0x110
[ 14.028570] arch_call_rest_init+0x1c/0x30
[ 14.028575] tegra-xusb 3610000.usb: HCD shut down
[ 14.028577] start_kernel+0x6d0/0x718
[ 14.028579] __primary_switched+0xbc/0xc4
[ 14.028582] —[ end trace 172db6a214c05241 ]—
[ 14.028601] tegra-xusb 3610000.usb: failed to set SS PP -65536
[ 14.028605] tegra-xusb 3610000.usb: HCD shut down
[ 14.028606] tegra-xusb 3610000.usb: HCD shut down
[ 14.028629] tegra-xusb 3610000.usb: HCD shut down
[ 14.028652] tegra-xusb 3610000.usb: HCD shut down
[ 14.028675] tegra-xusb 3610000.usb: HCD shut down
[ 14.028697] tegra-xusb 3610000.usb: HCD shut down
[ 14.028720] tegra-xusb 3610000.usb: HCD shut down
[ 14.028742] tegra-xusb 3610000.usb: HCD shut down
[ 14.028765] tegra-xusb 3610000.usb: HCD shut down
[ 14.028787] tegra-xusb 3610000.usb: HCD shut down
[ 14.028809] tegra-xusb 3610000.usb: HCD shut down
[ 14.028832] tegra-xusb 3610000.usb: failed to set HS PP -65536
[ 15.242766] usb0: HOST MAC 2a:69:65:0d:29:84
[ 15.242774] usb0: MAC 2a:69:65:0d:29:85
[ 15.243251] usb1: HOST MAC 2a:69:65:0d:29:86
[ 15.243255] usb1: MAC 2a:69:65:0d:29:87
[ 15.251362] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[ 15.253430] pstore: Using crash dump compression: deflate
[ 15.255869] printk: console [ramoops-1]: printing thread started
[ 15.255896] printk: console [ramoops-1] enabled
[ 15.255900] pstore: Registered ramoops as persistent store backend
[ 15.255903] ramoops: using 0x200000@0x4725f0000, ecc: 0
[ 15.265166] l4tbr0: port 1(usb0) entered blocking state
[ 15.265183] l4tbr0: port 1(usb0) entered disabled state
[ 15.266755] device usb0 entered promiscuous mode
[ 15.275654] l4tbr0: port 2(usb1) entered blocking state
[ 15.275672] l4tbr0: port 2(usb1) entered disabled state
[ 15.276088] device usb1 entered promiscuous mode
[ 15.282365] loop0: detected capacity change from 0 to 32768
[ 15.400076] nvgpu: 17000000.gpu gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 16.457906] zram: Added device: zram0
[ 16.458191] zram: Added device: zram1
[ 16.460203] zram: Added device: zram2
[ 16.467091] zram: Added device: zram3
[ 16.467284] zram: Added device: zram4
[ 16.492209] zram: Added device: zram5
[ 16.492646] zram: Added device: zram6
[ 16.513002] zram: Added device: zram7
[ 16.534379] zram0: detected capacity change from 0 to 2003976
[ 16.542196] Adding 1001984k swap on /dev/zram0. Priority:5 extents:1 across:1001984k SS
[ 16.548450] zram1: detected capacity change from 0 to 2003976
[ 16.554242] Adding 1001984k swap on /dev/zram1. Priority:5 extents:1 across:1001984k SS
[ 16.557655] zram2: detected capacity change from 0 to 2003976
[ 16.565080] Adding 1001984k swap on /dev/zram2. Priority:5 extents:1 across:1001984k SS
[ 16.566960] zram3: detected capacity change from 0 to 2003976
[ 16.573087] Adding 1001984k swap on /dev/zram3. Priority:5 extents:1 across:1001984k SS
[ 16.575096] zram4: detected capacity change from 0 to 2003976
[ 16.581500] Adding 1001984k swap on /dev/zram4. Priority:5 extents:1 across:1001984k SS
[ 16.583187] zram5: detected capacity change from 0 to 2003976
[ 16.589371] Adding 1001984k swap on /dev/zram5. Priority:5 extents:1 across:1001984k SS
[ 16.591027] zram6: detected capacity change from 0 to 2003976
[ 16.597430] Adding 1001984k swap on /dev/zram6. Priority:5 extents:1 across:1001984k SS
[ 16.599357] zram7: detected capacity change from 0 to 2003976
[ 16.605352] Adding 1001984k swap on /dev/zram7. Priority:5 extents:1 across:1001984k SS
[ 18.079297] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 540.3.0 Release Build (buildbrain@mobile-u64-6367-d8000) Mon May 6 10:21:06 PDT 2024
[ 18.338217] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 21.104240] rfkill: input handler disabled
[ 29.657997] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
I’m quite new to the world of remote work, but recently I discovered madcash.pro while browsing for reliable info about online earnings. The content feels real, not just promises or hype. There are guides for total beginners, and that’s exactly what I needed. Maybe you’ll find something helpful there as well.
