jetson agx orin在使用ota升级包的过程中失败
请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
[*] Jetson AGX Orin
Jetson Orin NX
Jetson Orin Nano
Jetson AGX Xavier
Jetson Xavier NX
Jetson TX 系列
Jetson Nano
Jetson 软件
JetPack 5.1.3
[*] JetPack 5.1.4
JetPack 6.0
JetPack 6.1
JetPack 6.2
DeepStream SDK
NVIDIA Isaac
SDK Manager 管理工具版本
2.3.0
2.2.0
2.1.0
[*] 其他
问题描述
将35.1.4升级到35.6生成的OTA包下载到jetson的板子上以后无论使用35.1.4的OTA工具包还是使用35.6的OTA工具包都会显示一样的报错
错误日志
v_ota_start.sh /home/nvidia/ota/ota_payload_package.tar.gz
[sudo] password for nvidia:
Command: ./nv_ota_start.sh /home/nvidia/ota/ota_payload_package.tar.gz
Current rootfs is on /dev/mmcblk0
init_ota_log /ota_log
Creating log dir at /ota_log
Create log file at /ota_log/ota_20230315-193207.log
OTA_LOG_FILE=/ota_log/ota_20230315-193207.log
Extract /home/nvidia/ota/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
3701–0004–1–jetson-agx-orin-devkit-
Info. Installing mtdblock.
Info. Active boot storage: mmcblk0
Info. Legacy mode: false
TNSPEC 3701-501-0004-E.0-1-1-jetson-agx-orin-devkit-
COMPATIBLE_SPEC 3701–0004–1–jetson-agx-orin-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE mmcblk0
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3701–0004–1–jetson-agx-orin-devkit-.
Info. Uninstalling mtdblock.
check_prerequisites
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Wed 15 Mar 2023 07:32:37 PM UTC
Sha1 checksum for /ota_work/ota_package.tar (565a201561c69c1a084cb64bb5923efaf87ef9e6) matches
decompress_ota_package: end at Wed 15 Mar 2023 07:32:51 PM UTC
nv_ota_update_without_layout_change.sh
Command: nv_ota_update_without_layout_change.sh
check_target_board /ota_work TARGET_BOARD
get_chip_id CHIP_ID
ota_choose_images /ota_work
COMPATIBLE_SPEC=3701–0004–1–jetson-agx-orin-devkit-
TEGRA_CHIPID=0x23
_BOARD_SPEC_NAME=3701–0004-
Copy files from ./images-R35-ToT/3701–0004-/ to ./images-R35-ToT/
is_rootfs_a_b_enabled ROOTFS_AB_ENABLED ROOTFS_CURRENT_SLOT
ROOTFS_AB_ENABLED=0
ROOTFS_CURRENT_SLOT=0
is_rootfs_encryption_enabled ROOTFS_ENC_ENABLED
ROOTFS_ENC_ENABLED=0
get_update_slot UPDATE_SLOT
UPDATE_SLOT=B
get_update_control /ota_work UPDATE_BOOTLOADER UPDATE_ROOTFS
UPDATE_BOOTLOADER=1, UPDATE_ROOTFS=1
select_uefi_capsule /ota_work
check_bsp_version /ota_work BASE_VERSION
The version of OTA package(R35-6) does not match the version of current system(R35-4), please check whether the OTA package is correct
Failed to run “check_bsp_version /ota_work BASE_VERSION”
是不是用的差分升级包,使用差分升级包的户话 升级包必须与被升级目标的版本匹配。
是的,这个问题已经解决了感谢回答
请问能否为我回答一下为什么我在TARGET_BSP替换过的image和dtb以及设置的user信息在构建ota包后在板子上使用OTA升级以后这些都没有适配成功?
