请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson AGX Orin
Jetson Orin NX
Jetson Orin Nano
Jetson AGX Xavier
Jetson Xavier NX
Jetson TX 系列
Jetson Nano
Jetson 软件
JetPack 5.1.3
JetPack 5.1.4
JetPack 6.0
JetPack 6.1
DeepStream SDK
NVIDIA Isaac
SDK Manager 管理工具版本
2.1.0
其他
问题描述
Jetson agx orin 更换为AR8035千兆网卡报错。连通不上。
设备树配置
/* EQOS */
ethernet@2310000 {
status = "okay";
nvidia,mac-addr-idx = <0>;
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
phy-mode = "rgmii-id";
phy-handle = <&phy>;
/delete-node/ fixed-link;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
#timestamper = <&phy>;
phy: phy@0 {
//compatible = "ethernet-phy-ieee802.3-c45";
compatible = "ethernet-phy-id004d.d072";
reg = <0x04>;
// phy_rst_lp_mode = <1>;
qca,clk-out-frequency = <125000000>;
qca,clk-out-strength = <1>;
//qca,keep-pll-enabled;
nvidia,phy-rst-pdelay-msec = <2240>; /* msec */
nvidia,phy-rst-duration-usec = <100000>; /* usec */
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
status = "okay";
错误码
[ 1069.000712] nvethernet 2310000.ethernet: [poll_check][43][type:0x4][loga-0x0]
poll_check: timeout
错误日志
[ 1070.088318] nvethernet 2310000.ethernet: [poll_check][43][type:0x4][loga-0x0] poll_check: timeout
[ 1070.097476] osi_readla addr=0000000035c37daf value=1
请在此处粘贴完整的程序日志。如果有多个日志,请使用多个文本框
