1. Reference
Reference documentation:
2. Modified Files and Configuration
BSP directory:
~/nvidia/nvidia_sdk/JetPack_7.2.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
File:
p3701.conf.common
Line 173:
ODMDATA="gbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0";
Kernel Device Tree
Directory:
~/nvidia/nvidia_sdk/JetPack_7.2.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb
File:
tegra234-p3737-0000+p3701-0005-nv.dtb
The DTB was decompiled and the following configuration was added:
+ pcie@14180000 {
+ status = "okay";
+ phys = <&p2u_hsio_0>;
+ phy-names = "p2u-0";
Pinmux Configuration
Directory:
~/nvidia/nvidia_sdk/JetPack_7.2.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT
File:
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
The following pinmux configuration was modified:
@@ -1486,9 +1486,9 @@
pex_l0_clkreq_n_pk0 {
nvidia,pins = "pex_l0_clkreq_n_pk0";
- nvidia,function = "rsvd1";
+ nvidia,function = "pe0";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
- nvidia,tristate = <TEGRA_PIN_ENABLE>;
+ nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
@@ -1496,10 +1496,10 @@
pex_l0_rst_n_pk1 {
nvidia,pins = "pex_l0_rst_n_pk1";
- nvidia,enable-input = <TEGRA_PIN_ENABLE>;
+ nvidia,enable-input = <TEGRA_PIN_DISABLE>;
3. Debug Environment
JetPack version: 7.2.1
Linux kernel version: 6.8.12
Platform: Jetson AGX Orin 64GB
PCIe: C0
Issue: PCIe C0 configuration
Could you please help me confirm whether this configuration is correct?
Thanks
