请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson AGX Xavier
Jetson 软件
JetPack 5.1.5
SDK Manager 管理工具版本
2.3.0
问题描述
之前系统是jetpack5.1.5,后来开机无法进入系统,卡在nvidia logo那。
然后通过在一台ubuntu20.04电脑上安装SDK Manager,通过使用usb转typeC线给jetson agv xavier烧录jetpack5.1.5 ,在step3,选择flash后,烧录一段时间后,就会出现失败.
错误码
ERROR: Flash Jetson Linux - flash: Error:Return value 8
ERROR: Flash Jetson Linux - flash:[exec_command]: /bin/bash -c /home/wmkj/.nvsdkm/replays/scripts/JetPack_5.1.5_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh;[error]:89255 blocks
ERROR: Flash Jetson Linux - flash:command error code: 11
ERROR: Flash Jetson Linux - flash:command terminated with error
错误日志
15:46:13 INFO:Flash Jetson Linux- flash:[2.0670][…100%
15:46:13 INFO:Flash Jetson Linux-flash:[2.0706 ] Sending bct_mem
15:46:13 INFO:Flash Jetson Linux- flash:[2.1178]…100%
15:46:13 ERROR:Flash Jetson Linux- flash:Error:Return value 8
15:46:13INFo:FlashJetonLinuxflash:Commandtegrarcmv–instance13–ownloadbctbootrambrbctBbct–dowoad bctmb1mb1_bct_M1_sigheader.bct.encrypt–downloadbct_memmem_rcm_sigheader.bt.encrypt
15:46:13 INFO:Flash Jetson Linux-flash:Cleaning up…
15:46:13ERROR:FlashJetson Linux-flash:[exec_command]:/bin/bash-c/home/wmkj/.nvsdkm/replays/scripts/JetPack 5.1.5Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh;[error]:89255 blocks
15:46:13 INFO:Flash Jetson Linux- flash:[Component Install Finished with Error ]
15:46:13 INFO: Flash Jetson Linux- flash:[host] [5.96 GB used.Disk Avail on Partition /dev/nvme@n1p2:274.74 GB ]
15:46:13 ERROR:Flash Jetson Linux- flash:command error code:11
15:46:13 ERROR: Flash Jetson Linux - flash: command terminated with error
15:46:13 SUMMARY:Flash Jetson Linux -flash:Installation failed.
15:46:13 SUMMARY:Multimedia API - target:Depends on failed component
15:46:13 SuMMARY:TensorRT on Target - target: Depends on failed component
15:46:13 SUMMARY:TensorRT Runtime -target:Depends on failed component
