isaac sim 一修改插件就报fail to solve ext dependence error
错误详情
2024-06-26 07:35:54 [47,438ms] [Error] [omni.ext._impl._internal] Failed to import python module loadCob_python from /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob. Error: source code string cannot contain null bytes. Traceback:
Traceback (most recent call last):
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/omni/ext/_impl/_internal.py", line 187, in _custom_importer
    return _import_public(ext_module.path, ext_module.name, reload_enabled)
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/carb/profiler/__init__.py", line 83, in wrapper
    r = f(*args, **kwds)
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/omni/ext/_impl/_internal.py", line 94, in _import_public
    module = import_module(module_name)
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
    return importlib.import_module(name)
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/python/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob/loadCob_python/__init__.py", line 9, in <module>
    from .extension import *
  File "/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob/loadCob_python/extension.py", line 25, in <module>
    from .ui_builder import UIBuilder
ValueError: source code string cannot contain null bytes
2024-06-26 07:35:54 [47,438ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'loadCob_python' in '/home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob' failed to load.
At:
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/omni/ext/_impl/_internal.py(213): startup
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/omni/ext/_impl/_internal.py(328): startup_extension
  PythonExtension.cpp::startup()(2): <module>
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.kit.window.extensions/omni/kit/window/extensions/ext_commands.py(29): do
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.kit.commands/omni/kit/undo/undo.py(80): execute
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.kit.commands/omni/kit/commands/command.py(463): execute
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.kit.window.extensions/omni/kit/window/extensions/common.py(288): toggle_extension
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.kit.window.extensions/omni/kit/window/extensions/ext_components.py(93): toggle
2024-06-26 07:35:54 [47,438ms] [Error] [omni.ext.plugin] [ext: loadCob-1.0.0] Failed to startup python extension.
2024-06-26 07:35:54 [47,659ms] [Error] [omni.ext.python] ValueError: source code string cannot contain null bytes
At:
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob/loadCob_python/extension.py(25): <module>
  <frozen importlib._bootstrap>(241): _call_with_frames_removed
  <frozen importlib._bootstrap_external>(883): exec_module
  <frozen importlib._bootstrap>(703): _load_unlocked
  <frozen importlib._bootstrap>(1006): _find_and_load_unlocked
  <frozen importlib._bootstrap>(1027): _find_and_load
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/loadCob/loadCob_python/__init__.py(9): <module>
  <frozen importlib._bootstrap>(1050): _gcd_import
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/python/lib/python3.10/importlib/__init__.py(126): import_module
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.graph/omni/graph/core/_impl/_registration/extension_management.py(154): extension_management_factory
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.graph/omni/graph/core/_impl/_registration/register_python_ogn.py(70): register_python_ogn
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/kernel/py/carb/profiler/__init__.py(85): wrapper
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.graph/omni/graph/core/_impl/registration.py(34): __init__
  /home/d/.local/share/ov/pkg/isaac-sim-2023.1.1/kit/exts/omni.graph/omni/graph/core/_impl/extension.py(120): on_after_ext_enabled
我非常确定代码没有问题,因为我只加了一个新行
Hi @nvijj,
欢迎访问我们的开发者论坛!已经看到您的问题了,能否提供一下使用的硬件和软件环境。这样方便我们排查问题。比如通过什么什么步骤可以复现错误?
硬件:RTX3060Ti , i7
软件:驱动 Driver Version: 535.171.04
cuda
Built on Fri_Dec_17_18:16:03_PST_2021
Cuda compilation tools, release 11.6, V11.6.55
Build cuda_11.6.r11.6/compiler.30794723_0
系统:ubuntu20.04
Hi nvijj,
请问sim版本是4.0 4.1吗,如果是基于4.0及以上,请提供下复现步骤,我们复现看下。
谢谢
