Isaac lab 仿真报错
return self.root_com_ang_vel_b
File "c:/isaaclab/source/isaaclab/isaaclab/assets/articulation/articulation_data.py", line 837, in root_com_ang_vel_b
    return math_utils.quat_apply_inverse(self.root_link_quat_w, self.root_com_ang_vel_w)
RuntimeError: nvrtc: error: invalid value for --gpu-architecture (-arch)
nvrtc compilation failed:
#define NAN __int_as_float(0x7fffffff)
#define POS_INFINITY __int_as_float(0x7f800000)
#define NEG_INFINITY __int_as_float(0xff800000)
template<typename T>
__device__ T maximum(T a, T b) {
  return isnan(a) ? a : (a > b ? a : b);
__device__ T minimum(T a, T b) {
  return isnan(a) ? a : (a < b ? a : b);
extern "C" __global__
void fused_mul_sub_add(float* tv_, float* tvec_7, float* tv__, float* tt_1, float* aten_add) {
  float v = __ldg(tvec_7 + ((long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)) % 3ll + 2ll * ((((long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)) / 3ll) * 3ll));
  float v_1 = __ldg(tv__ + 7ll * (((long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)) / 3ll));
  float v_2 = __ldg(tt_1 + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
  float v_3 = __ldg(tv_ + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
  aten_add[(long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)] = (v - v_1 * v_2) + v_3;
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
2026-03-11 17:13:18 [14,999ms] [Warning] [omni.fabric.plugin] gFabricState->gUsdStageToSimStageWithHistoryMap had 1 outstanding SimStageWithHistory(s) at shutdown
2026-03-11 17:13:18 [15,168ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
后面就崩溃了
解决了hhhh
H i13276905497,
感谢同步结果,RuntimeError: nvrtc: error: invalid value for --gpu-architecture (-arch),这类问题一般是cuda版本和显卡不匹配,卡比较新,通过升级torch这些到新版本.
你是升级了torch这些解决的吗?
