Is it feasible to replace rootfs before encrypting Orin NX, and are my steps correct?
请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson Orin NX
Jetson 软件
JetPack 6.2
他
问题描述
I want to replace the rootfs under Linux_for_Tegra (copied from the NVMe of another working Orin NX board) before performing full-disk encryption on my Orin NX, then flash and encrypt the system.I need to know:
  1. Is this method feasible?
  2. Are my detailed steps below correct?
My full steps:
  1. Generate encryption keys
cd Linux_for_Tegra
  1. Replace Linux_for_Tegra/rootfs with the rootfs copied from another Orin NX board’s NVMe
  2. Generate 32-byte keys (sym2_t234.key)
cd source/tegra/optee-src/nv-optee/optee/samples/hwkey-agent/host/tool/gen_ekb/
openssl rand -hex 32 > sym_t234.key
openssl rand -hex 16 > sym2_t234.key
openssl rand -hex 16 > auth_t234.key
openssl rand -hex 32 > oem_k1.key
echo "0000000000000000000000000000000000000000000000000000000000000000" > oem_k1.key
  1. Generate EKS image
./example.sh
# Verify EKS header (EEKB)
hexdump -C -n 4 -s 0x34 eks_t234.img
# Copy files
cp eks_t234.img /home/nvidia_jetson_orin_nx_Sources/Linux_for_Tegra/bootloader/
cp sym2_t234.key /home/nvidia_jetson_orin_nx_Sources/Linux_for_Tegra/
cd /home/nvidia_jetson_orin_nx_Sources/Linux_for_Tegra/
  1. Put Orin NX into RCM recovery mode
  2. Clean old images and signature files
sudo rm -rf tools/kernel_flash/images/*
sudo rm -rf bootloader/signed/*
sudo rm -rf bootloader/flash.idx
  1. Generate QSPI image and signature files
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --erase-all --network usb0 \
--showlogs -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--no-flash jetson-orin-nano-devkit internal
chmod +x bootloader -Rf
  1. Copy encrypted header files
sudo cp bootloader/eks_t234_sigheader.img.encrypt ./tools/kernel_flash/images/internal/
  1. Generate encrypted rootfs image
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --erase-all --showlogs --no-flash --external-device nvme0n1p1 -i /home/nvidia_jetson_orin_nx_Sources/Linux_for_Tegra/sym2_t234.key -S 230GiB -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 jetson-orin-nano-devkit external
  1. Flash images
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --erase-all --network usb0 --showlogs --flash-only
My actual result:
  • System can boot
  • But some drivers fail and system services abnormal
  • TEE / fTPM errors appear
  • sudo permission broken
Please help check:
  • Is replacing rootfs before encryption supported?
  • Which step is wrong?
  • How to fix driver/service issues after encryption?
