ibmdx360m4服务器系统说centos7.5安装英伟达v100显卡驱动不成功
今天我们给客户的一些ibmdx360m4机器安装centos7.5系统,然后再带两块英伟达特斯拉的v100显卡,再我们装驱动时老装不上,报错如下希望有能人能帮忙解决
ry to reconfigure PCIe (mem BAR) address space (MMIO) settings in RBSU/BIOS (something like “MMIO above 4G” or “Above 4G Decoding”, or “MMIO base” set to lower value) or remove/disable other unnecessary add-on cards and use 64bit OS. HPE RBSU/BIOS have problems with that (see similar problems To check address space requirements use “lspci -s 24:00.0 -vv | grep Region”.
PS: Tesla M40 is for “Deep Learning”/CUDA processing not for GPU/vGPU and you can check more relevant forums
