如何才能达到 H265下 8路视频编码 1080p 30fps 的参数
请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson Orin NX
Jetson 软件
JetPack 5.1.1
操作过程:
1.生成yuv文件(仅供参考 任意1080p文件均可)
#生成文件
nvidia@miivii-tegra:/usr/src/jetson_multimedia_api/samples/15_multivideo_encode$
sudo ffmpeg -f lavfi -i testsrc=size=1920x1080:rate=30:duration=10 -pix_fmt yuv420p -y …/07_video_convert/video420.yuv0
2.进入nvidia 的视频编码api,修改multivideo_encode_main.cpp
cd /usr/src/jetson_multimedia_api/samples/15_multivideo_encode
在multivideo_encode_main.cpp中添加记录编码完成时间的代码。
修改后的文件如下:
multivideo_encode_main.txt (35.1 KB)
编译:sudo make
3.运行 8路1080p 视频编码 查看是否达到1080p 30FPS的纸面参数
运行命令如下:
sudo ./multivideo_encode num_files 8 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test1.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test2.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test3.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test4.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test5.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test6.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test7.h265 \
…/07_video_convert/video420.yuv0 1920 1080 H265 test8.h265 \
异常现象
在8路1080p30帧下 H265 编码延时就会大于帧间隔
输出可见日志:
nvidia@miivii-tegra:/usr/src/jetson_multimedia_api/samples/15_multivideo_encode$ sudo ./multivideo_encode num_files 8 ../07_video_convert/video420.yuv0 1920 1080 H265 test1.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test2.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test3.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test4.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test5.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test6.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test7.h265 ../07_video_convert/video420.yuv0 1920 1080 H265 test8.h265 \
Creating Encoder in blocking mode
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 8
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
892744264
842091865
892744264
842091865
NvVideo: H265 : Profile : 1
NVMEDIA: Need to set EMC bandwidth : 846000
NvVideo: bBlitMode is set to TRUE
892744264
842091865
892744264
842091865
892744264
842091865
892744264
842091865
892744264
842091865
892744264
842091865
通道 4 帧 6 编码间隔: 39ms
通道 6 帧 3 编码间隔: 46ms
通道 0 帧 22 编码间隔: 35ms
通道 3 帧 18 编码间隔: 39ms
通道 2 帧 10 编码间隔: 39ms
通道 4 帧 7 编码间隔: 45ms
通道 0 帧 23 编码间隔: 35ms
通道 6 帧 4 编码间隔: 59ms
通道 3 帧 19 编码间隔: 39ms
通道 2 帧 11 编码间隔: 43ms
通道 4 帧 8 编码间隔: 43ms
通道 6 帧 5 编码间隔: 44ms
通道 1 帧 25 编码间隔: 35ms
通道 3 帧 20 编码间隔: 37ms
通道 2 帧 12 编码间隔: 38ms
通道 4 帧 9 编码间隔: 42ms
通道 3 帧 21 编码间隔: 37ms
通道 2 帧 13 编码间隔: 35ms
通道 7 帧 5 编码间隔: 35ms
通道 2 帧 14 编码间隔: 35ms
通道 6 帧 8 编码间隔: 35ms
通道 7 帧 6 编码间隔: 35ms
通道 1 帧 30 编码间隔: 34ms
通道 7 帧 8 编码间隔: 34ms
通道 0 帧 30 编码间隔: 36ms
通道 3 帧 25 编码间隔: 35ms
通道 5 帧 21 编码间隔: 35ms
通道 4 帧 14 编码间隔: 35ms
通道 2 帧 17 编码间隔: 35ms
通道 6 帧 11 编码间隔: 35ms
通道 1 帧 31 编码间隔: 36ms
通道 7 帧 9 编码间隔: 36ms
通道 0 帧 31 编码间隔: 36ms
通道 3 帧 26 编码间隔: 36ms
通道 5 帧 22 编码间隔: 35ms
通道 4 帧 15 编码间隔: 36ms
通道 2 帧 18 编码间隔: 36ms
通道 6 帧 12 编码间隔: 36ms
通道 1 帧 32 编码间隔: 34ms
通道 7 帧 10 编码间隔: 34ms
通道 3 帧 30 编码间隔: 34ms
通道 5 帧 26 编码间隔: 34ms
通道 4 帧 19 编码间隔: 35ms
通道 2 帧 22 编码间隔: 35ms
通道 6 帧 16 编码间隔: 35ms
通道 1 帧 36 编码间隔: 34ms
通道 7 帧 14 编码间隔: 35ms
通道 0 帧 36 编码间隔: 34ms
通道 3 帧 31 编码间隔: 35ms
通道 5 帧 27 编码间隔: 35ms
通道 4 帧 20 编码间隔: 35ms
通道 2 帧 23 编码间隔: 35ms
通道 6 帧 17 编码间隔: 35ms
通道 1 帧 37 编码间隔: 34ms
通道 7 帧 15 编码间隔: 35ms
通道 0 帧 37 编码间隔: 34ms
通道 5 帧 30 编码间隔: 35ms
通道 4 帧 23 编码间隔: 34ms
通道 2 帧 26 编码间隔: 34ms
通道 6 帧 20 编码间隔: 35ms
通道 1 帧 40 编码间隔: 35ms
通道 7 帧 18 编码间隔: 35ms
通道 0 帧 40 编码间隔: 34ms
通道 3 帧 35 编码间隔: 35ms
通道 5 帧 31 编码间隔: 34ms
通道 4 帧 24 编码间隔: 34ms
通道 2 帧 27 编码间隔: 34ms
通道 6 帧 21 编码间隔: 34ms
通道 1 帧 41 编码间隔: 34ms
通道 7 帧 19 编码间隔: 35ms
通道 0 帧 41 编码间隔: 34ms
通道 3 帧 36 编码间隔: 35ms
通道 2 帧 30 编码间隔: 34ms
通道 6 帧 24 编码间隔: 35ms
通道 1 帧 44 编码间隔: 34ms
通道 7 帧 22 编码间隔: 35ms
通道 0 帧 44 编码间隔: 34ms
通道 3 帧 39 编码间隔: 34ms
通道 5 帧 35 编码间隔: 35ms
通道 4 帧 28 编码间隔: 35ms
通道 2 帧 31 编码间隔: 35ms
通道 6 帧 25 编码间隔: 35ms
通道 1 帧 45 编码间隔: 34ms
Could not read complete frame from input file
File read complete.
File read complete.
通道 3 帧 286 编码间隔: 34ms
通道 6 帧 272 编码间隔: 34ms
通道 4 帧 275 编码间隔: 34ms
通道 2 帧 278 编码间隔: 34ms
通道 5 帧 282 编码间隔: 34ms
通道 7 帧 270 编码间隔: 34ms
通道 3 帧 287 编码间隔: 35ms
通道 6 帧 273 编码间隔: 34ms
通道 4 帧 276 编码间隔: 34ms
通道 5 帧 283 编码间隔: 34ms
通道 7 帧 271 编码间隔: 34ms
File read complete.
通道 5 帧 286 编码间隔: 34ms
通道 7 帧 274 编码间隔: 34ms
通道 6 帧 277 编码间隔: 34ms
通道 4 帧 280 编码间隔: 34ms
通道 2 帧 283 编码间隔: 34ms
通道 5 帧 287 编码间隔: 35ms
通道 7 帧 275 编码间隔: 34ms
通道 6 帧 278 编码间隔: 34ms
通道 4 帧 281 编码间隔: 34ms
通道 2 帧 284 编码间隔: 34ms
Got 0 size buffer in capture
通道 4 帧 282 编码间隔: 35ms
通道 2 帧 285 编码间隔: 35ms
File read complete.
Instance 1 executed successfully.
Instance 0 executed successfully.
File read complete.
Instance 3 executed successfully.
File read complete.
File read complete.
Instance 5 executed successfully.
File read complete.
Instance 2 executed successfully.
Instance 4 executed successfully.
Instance 6 executed successfully.
Instance 7 executed successfully.
App run was successful
其他尝试:
1.sudo jetson_clocks >>> 依旧出现大于33ms的帧
2.降低码率 bitrate = 1 * 1024 * 1024 , 4M将至1M 与2M >>> 依旧出现问题
3.尝试每个进程执行一路,同时执行7个进程 >>> 依旧出现问题
nvidia@miivii-tegra:/usr/src/jetson_multimedia_api/samples/15_multivideo_encode$ sudo cat test.sh
#!/bin/bash
切换到脚本所在目录或使用绝对路径
cd /path/to/your/directory
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test1.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test2.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test3.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test4.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test5.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test6.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test7.h265 &
sudo ./multivideo_encode num_files 1 …/07_video_convert/video420.yuv0 1920 1080 H265 test8.h265 &
等待所有后台进程完成
wait
echo “所有编码任务已完成”
疑问点
1.这样逐帧计算编码完成时间是否正确
2.如何才能达到 H265下 8路视频编码 1080p 30fps 的参数
