CUgraphicsResource资源创建与释放异常
error输出为Unmap failed: 999,具体的现象为图像处理函数apply_image_processing每一次调用时输入为上一次的处理结果
我想得到代码debug的帮助,是否存在相关资源在每一帧的处理前没有被正确的初始化?
回调函数handoff_handler:
static void handoff_handler(GstElement* identity, GstBuffer* buffer, GstPad* pad, gpointer user_data) {
// 确保 CUDA 设备已初始化
static bool cuda_initialized = false;
if (!cuda_initialized) {
cudaSetDevice(0);
// cudaFree(0); // 初始化上下文
cuda_initialized = true;
// 打印内存信息
size_t free_memory, total_memory;
cudaMemGetInfo(&free_memory, &total_memory);
printf("GPU Memory: %zu MB free, %zu MB total\n", free_memory / (1024 * 1024), total_memory / (1024 * 1024));
frame_count++;
gint64 current_time = g_get_monotonic_time();
// FPS计算
if (current_time - last_print_time > G_USEC_PER_SEC) {
gdouble fps = (gdouble)frame_count * G_USEC_PER_SEC / (current_time - last_print_time);
printf("FPS: %.2f\n", fps);
frame_count = 0;
last_print_time = current_time;
// 从 GstBuffer 获取 NvBufSurface
NvBufSurface* surf = nullptr;
// 获取 NvBufSurface
GstMapInfo map_info;
if (!gst_buffer_map(buffer, &map_info, GST_MAP_READWRITE)) {
printf("Failed to map buffer\n");
return;
// 获取 NvBufSurface 指针
surf = (NvBufSurface*)map_info.data;
if (!surf || surf->numFilled <= 0) {
printf("Failed to get NvBufSurface\n");
gst_buffer_unmap(buffer, &map_info);
return;
// 打印bufer信息
int p;
printf("identity->surf : \n");
printf(" batchSize = %d\n", surf->batchSize);
printf(" numFilled = %d\n", surf->numFilled);
printf(" memType = %d\n", surf->memType);
for (int bs = 0; bs < surf->batchSize; bs++) {
NvBufSurfaceParams *sur = &(surf->surfaceList[bs]);
if (sur == NULL)
break;
printf(" surfaceList[%d]:\n", bs);
printf(" width = %d\n", sur->width);
printf(" height = %d\n", sur->height);
printf(" pitch = %d\n", sur->pitch);
printf(" layout = %d\n", sur->layout);
printf(" colorFormat = %d\n", sur->colorFormat);
printf(" bufferDesc = %lu\n", sur->bufferDesc);
printf(" dataSize = %d\n", sur->dataSize);
printf(" dataPtr = %p\n", sur->dataPtr);
if(sur->colorFormat == NVBUF_COLOR_FORMAT_NV12_ER)
printf("it's NVBUF_COLOR_FORMAT_NV12_ER!\n");
else
printf("it's not NVBUF_COLOR_FORMAT_NV12_ER(%d)\n", NVBUF_COLOR_FORMAT_NV12_ER);
NvBufSurfacePlaneParams *planeParams = &(sur->planeParams);
printf(" NvBufSurfaceParams->planeParams:\n");
printf(" num_planes = %d\n", planeParams->num_planes);
for (p = 0; p < planeParams->num_planes; p++) {
printf(" width[%d] = %u\n", p, planeParams->width[p]);
printf(" height[%d] = %u\n", p, planeParams->height[p]);
printf(" pitch[%d] = %u\n", p, planeParams->pitch[p]);
printf(" offset[%d] = %u\n", p, planeParams->offset[p]);
printf(" psize[%d] = %u\n", p, planeParams->psize[p]);
printf(" bytesPerPix[%d] = %u\n", p, planeParams->bytesPerPix[p]);
NvBufSurfaceMappedAddr *mAddr = &(sur->mappedAddr);
printf(" NvBufSurfaceParams->mappedAddr:\n");
for (p = 0; p < NVBUF_MAX_PLANES; p++) {
if (!mAddr->addr) {
printf(" mappedAddr->addr[%d] is NULL\n", p);
break;
printf(" mappedAddr->addr[%d] = %p\n", p, mAddr->addr[p]);
if (mAddr->eglImage == NULL)
printf(" mappedAddr->eglImage is NULL\n");
else
printf(" mappedAddr->eglImage is %p\n", mAddr->eglImage);
// ---------------------------------------------------------------------------- CUDA 版本 ---------------------------------------------------------------------------------
// map EGLImage
if (NvBufSurfaceMapEglImage(surf, 0) != 0) {
printf("Failed to map EGLImage");
return;
// 修改:从 surf 结构中获取Y平面 EGLImage
EGLImageKHR egl_image_y = surf->surfaceList[0].mappedAddr.eglImage;
if (egl_image_y == EGL_NO_IMAGE_KHR) {
printf("EGLImage is NULL after mapping\n");
NvBufSurfaceUnMapEglImage(surf, 0);
return;
// 使用CUDA接口注册EGLImage
CUgraphicsResource cuResource;
CUresult cuRes = cuGraphicsEGLRegisterImage(&cuResource, egl_image_y, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
if (cuRes != CUDA_SUCCESS) {
printf("cuGraphicsEGLRegisterImage failed: %d\n", cuRes);
return;
printf("CUDA EGL registration successful\n");
// 映射CUDA资源
CUeglFrame egl_frame_y;
cuRes = cuGraphicsResourceGetMappedEglFrame(&egl_frame_y, cuResource, 0, 0);
printf("cuGraphicsResourceGetMappedEglFrame failed with error code %d\n", cuRes);
cuGraphicsUnmapResources(1,&cuResource,0);
cuGraphicsUnregisterResource(cuResource);
return;
printf("cuGraphicsResourceGetMappedEglFrame successful\n");
printf(" frame.width = %d\n", egl_frame_y.width);
printf(" frame.height = %d\n", egl_frame_y.height);
// 获取 cuArray
CUarray cuArray_y = egl_frame_y.frame.pArray[0];
int width = surf->surfaceList[0].width;
int height = surf->surfaceList[0].height;
// 打印调试信息
printf("CUDA Array: %p\n", (void*)cuArray_y);
printf("Image dimensions: %d x %d\n", width, height);
// 控制标志
bool applyClahe = true;
bool applyBrightness = false;
float clipLimit = 0.1f;
int tileGridX = 8, tileGridY = 8;
float brightnessFactor = 1.5f;
// 调用统一处理函数
cudaError_t process_err = apply_image_processing(&cuArray_y, width, height, applyClahe, applyBrightness, clipLimit, tileGridX, tileGridY, brightnessFactor);
if (process_err != cudaSuccess) {
printf("Image processing failed: %s\n", cudaGetErrorString(process_err));
// --------------------------------------------------------------- CUDA end --------------------------------------------------------------------------------
// 同步设备
cudaDeviceSynchronize();
cuRes = cuGraphicsUnmapResources(1, &cuResource, 0);
printf("Unmap failed: %d\n", cuRes);
cuRes = cuGraphicsUnregisterResource(cuResource);
printf("cuGraphicsUnregisterResource failed: %d\n", cuRes);
if (NvBufSurfaceUnMapEglImage(surf, 0) != 0) {
printf("NvBufSurfaceUnMapEglImage failed\n");
bsah输出:
GPU Memory: 25891 MB free, 30697 MB total
identity->surf :
batchSize = 1
numFilled = 1
memType = 4
surfaceList[0]:
width = 5120
height = 1440
pitch = 5120
layout = 1
colorFormat = 7
bufferDesc = 61
dataSize = 11796480
dataPtr = 0xffff380632b0
num_planes = 2
width[0] = 5120
height[0] = 1440
pitch[0] = 5120
offset[0] = 0
psize[0] = 7864320
bytesPerPix[0] = 1
width[1] = 2560
height[1] = 720
pitch[1] = 5120
offset[1] = 7864320
psize[1] = 3932160
bytesPerPix[1] = 2
mappedAddr->addr[0] = (nil)
mappedAddr->addr[1] = (nil)
mappedAddr->addr[2] = (nil)
mappedAddr->addr[3] = (nil)
frame.width = 5120
frame.height = 1440
CUDA Array: 0xffff7494b800
Image dimensions: 5120 x 1440
===== Starting Image Processing =====
Image size: 5120 x 1440
Apply CLAHE: YES
Apply Brightness: NO
CLAHE parameters:
Clip limit: 0.10
Tile grid: 8 x 8
[CLAHE] Starting processing for 5120x1440 image
[CLAHE] Tile configuration: 8x8 tiles
[CLAHE] Clip limit: 0.10
[CLAHE] Tile size: 640x180 pixels
[CLAHE] Total tiles: 64
[CUDA] Using CUDA array: 0xffff7494b800
[CUDA] Texture object created: 0x1 (0.00 ms)
[CUDA] Surface object created: 0x2 (0.01 ms)
[MEM] Allocating histogram: 0.06 MB
[MEM] Histogram allocated: 0x205ce0000 (0.21 ms)
[MEM] Allocating CDF: 0.06 MB
[MEM] CDF allocated: 0x205cf0000 (0.01 ms)
[INIT] Zeroing histogram and CDF memory
[INIT] Histogram and CDF zeroed (0.06 ms)
[KERNEL] Launching computeHistogramKernel
Grid: (8, 8, 1)
Block: (256, 1, 1)
Shared memory: 1024 bytes
[KERNEL] computeHistogramKernel completed (0.50 ms)
[KERNEL] Launching clipAndComputeCDFKernel
Grid: (1, 1, 1)
Block: (256, 1, 1)
[KERNEL] clipAndComputeCDFKernel completed (0.28 ms)
[KERNEL] Launching applyEqualizationKernel
Grid: (320, 90, 1)
Block: (16, 16, 1)
[KERNEL] applyEqualizationKernel completed (0.78 ms)
[CLEANUP] Releasing resources
[CLEANUP] Resources released (0.22 ms)
[CLAHE] Processing completed successfully
Total processing time: 0.003 seconds
===== Image Processing Complete =====
Unmap failed: 999
