Failed to connect Isaac sim with Omniverse Streaming Client;
Hello everyone, here’s a question for you to answer;
ubutu22.04
Failed to connect Isaacsim with Omniverse Streaming Client;
The following error message is displayed:
main: thread_init: already added for thread
2024-05-08 07:57:53 [2,021,270ms] [Info] [carb.livestream.plugin] Stream server: connected stream 0x7f943c0292d0 on connection 0x7f945c042f10
2024-05-08 07:57:53 [2,021,280ms] [Info] [carb.livestream.plugin] Client (nil) disconnected.
2024-05-08 07:57:53 [2,021,286ms] [Info] [carb.livestream.plugin] Stream Server: stream0 0x7f945c042f10 (type 1) stopped
2024-05-08 07:57:53 [2,021,286ms] [Info] [carb.livestream.plugin] Stream Server: stream1 0x7f945c051f90 (type 4) stopped
2024-05-08 07:57:53 [2,021,286ms] [Info] [carb.livestream.plugin] Client (nil) disconnected.
Hi linkai_wang,
Could you ssh this IP on your host before streaming client test?
also make sure host sim start with headless mode and resolution can also check different choice.
Hello beyond_Jeff,
I can ssh this IP on my host before straming client test and I use the './runheadless.native.sh -v ’ command to start Isaac Sim,
Here’s the link, Isaac Sim | NVIDIA NGC
Hi linkai_wang,
Which stream client version you installed, I tested 103.1.1 it worked. have you tried diff display resolution when log in?
Hi beyond_Jeff,
Thanks for the answer, I’ll try to do it again later.
