cudaHostAlloc
在Nsight for Eclipse 使用 cudaHostAlloc就是不能识别
cudaHostAlloc ((void **)&a,3,cudaHostAllocMapped)
size_t size =3
cudaHostAlloc ((void **)&a,size,cudaHostAllocMapped)
cudaHostAlloc (a,3,cudaHostAllocMapped)
都不能识别
直接用nvcc 可以通过 只是随后的Zero copy没有拷贝进去任何内容 ,而cuda-memcheck a.out 查不出任何内容
size好像应该按字节数算,你试试size=3*sizeof(a的数据类型)行不。
换成sizeof(int) 不行 我的程序是这样的 有没有高手帮看看能不能调过
  • Copyright 1993-2012 NVIDIA Corporation. All rights reserved.
  • Please refer to the NVIDIA end user license agreement (EULA) associated
  • with this source code for terms and conditions that govern your use of
  • this software. Any use, reproduction, disclosure, or distribution of
  • this software and related documentation outside the terms of the EULA
  • is strictly prohibited.
    #include <stdlib.h>
    #include <cuda.h>
define N 3
global void add(int *a,int *b,int *c,int *dev_a,int dev_b,int dev_c){
int tid = blockIdx.x
blockDim.x +threadIdx.x;
printf(“%d \n”,tid);
*dev_a = *a;
*dev_b = *b;
*dev_c = *c;
printf(" tid : %d a : %d b: %d c: %d \n",tid,*a,*b,*c);
global void add(int *a,int *b,int c){
// if(tid <N) c[tid]= a[tid]+b[tid];
  • Host function that prepares data array and passes it to the CUDA kernel.
    int main(void) {
    int T =32,B =1;
    int *a = new int(1);
    int *b = new int(2);
    int *c = new int(3);
    int *dev_a,*dev_b,*dev_c;
cudaEvent_t start,stop;
float elapsed_time_ms;
size_t size =3;
*a = 1;
*b = 2;
*c = 3;
//cudaHostAlloc( (void**)&a, size, cudaHostAllocMapped || cudaHostAllocWriteCombined );
cudaHostAlloc( &a, 3sizeof(int), cudaHostAllocMapped); // word checking
printf("size : %d ",size);
// cudaHostAlloc( (void**)&b, size
sizeof(int), cudaHostAllocMapped || cudaHostAllocWriteCombined );
cudaHostAlloc( &b, size*sizeof(int), cudaHostAllocMapped);
cudaHostAlloc(&c, size, cudaHostAllocMapped );
// load arrays with some numbers
cudaHostGetDevicePointer(&dev_a, a, 0); // mem. copy to device not need now, but ptrs needed instead
cudaError_t cudaerr = cudaDeviceSynchronize();
if (cudaerr != CUDA_SUCCESS)printf(“Kernel launch filed with error 1 "%s".\n”,cudaGetErrorString(cudaerr));
cudaHostGetDevicePointer(&dev_b, b, 0);
if (cudaerr != CUDA_SUCCESS)printf(“Kernel launch filed with error 2 "%s".\n”,cudaGetErrorString(cudaerr));
cudaHostGetDevicePointer(&dev_c ,c, 0);
if (cudaerr != CUDA_SUCCESS)printf(“Kernel launch filed with error 3"%s".\n”,cudaGetErrorString(cudaerr));
// start time
cudaEventCreate(&start);
add<<<B,T>>>(a,b,c,dev_a,dev_b,dev_c);
if (cudaerr != CUDA_SUCCESS)printf(“Kernel launch filed with error 4"%s".\n”,cudaGetErrorString(cudaerr));
cudaThreadSynchronize(); // copy back not needed but now need thread synchronization
cudaEventCreate(&stop);
// end time
// print results
cudaEventElapsedTime(&elapsed_time_ms,start,stop);
printf(“Time to calculate results: %f ms.\n”, elapsed_time_ms); // print out execution time
cudaFreeHost(a); // clean up
cudaFreeHost(b);
cudaFreeHost(c);
cudaEventDestroy(start);
cudaEventDestroy(stop);
[i][i][i]return 0;
[/i][/i][/i]
楼主的“不能识别”存在歧义:
(1)如果是eclipse的IDE智能感知无法提示cudaHostAlloc()的原型信息,我建议楼主到eclipse的开发组询问此问题。
(2)如果是“随后的zero copy"不能成功(例如在kernel中读取host mapped memory中的内容失败), 则请注意:
(a)请检查是否存在2楼建议的问题。
(b)您的程序开头是否有cudaDeviceMapHost为参数(或者多个参数|之一有它)的cudaSetDeviceFlags函数调用。
(c)请检查失败是直接使用了cudaHostAlloc出的指针,而忘记使用cudaHostGetDevicePointer()来获取对应的设备指针。
(d)请检查您是否在kernel中使用的是HostGetDevicePointer出来的对应设备指针。
注意:如果您的卡支持并启用了unified addressing, 则您可以直接使用。无需单独获取设备指针。
注意:以上回答是对您的“cudaHostAlloc就是不能识别”进行推断出来的您的意思,并接着回答的。
如果您的意思不是我上文列出的2项,建议重新正确表达您的意图。(您也可以不表达,只是建议)
感谢您的来访。
您好
我把程序写在上面了 不在您给的建议之内 遇到问题的确比较棘手
用lspci -v 命令 NVIDIA Corporation Device 1140
驱动已经安装 是Geforce 630系列
您的问题(或者您存在多个问题之一)在我的建议范围内,
请看我的4#回复的(b)条:请使用cudaSetDeviceFlags(cudaDeviceMapHost)在贵main()函数体的开头。
您可以再次忽略此建议,我将按照您的要求,不再建议。
以及,如果您能接受此建议,我将不盛荣幸。
以及,请修改后重新汇报问题是否消失,本回答指出了一个问题,但并不排除没有更多其他的问题。
但我把主程序改成这样还是有问题
int T =32,B =1;
size_t size =3;
*a = 1;
*b = 2;
*c = 3;
cudaSetDeviceFlags(cudaDeviceMapHost);
int a =0;
cudaHostAlloc( &b, size, cudaHostAllocMapped);
cudaHostAlloc(&c, size*sizeof(int), cudaHostAllocMapped );
cudaHostGetDevicePointer((void **)&dev_a, (void *)a, 0); // mem. copy to device not need now, but ptrs needed instead
cudaHostGetDevicePointer((void **)&dev_b, (void *)b, 0);
cudaHostGetDevicePointer((void **)&dev_c ,(void *)c, 0);
// start time
楼主的逻辑上已经大致无问题了,
先设置flags,
在进行HostAllocaMapped参数的Host Allocation,
最后使用HostGetDevicePointer,
逻辑上这里是无问题,那么问题可能出在别的地方。
例如你的add kernel(你没有给出), 是否正确?
我看到它使用了3个缓冲区,分别是3 * sizeof(int)大小(缓冲区a), 3 Bytes(缓冲区b), 3 * sizeof(int)大小(缓冲区c), 如果您计算的是3个元素的向量相加。这里应该是不对的。
这是其一。
其二,楼主先对host上的指针a,b,c分配空间,并初始化为1,2,3; 然后再次初始化为1,2,3; 最后再次使用cudaHostMalloc, 再次分配,丢弃了原来分配的三次空间,是否符合愿意?
其三,楼主接受了对最后一次分配后的a,b,c取得device pointer。但却依然使用了:
<<<>>>(a,b,c,dev_a,dev_b,dev_c) (其中前3者是后3者的host pointer, 不考虑unified addressing的话)。
是否这里违背了您的原意?
请三思。
楼主的问题多多,但不妨先考虑上面的三个问题。先改正了再说。
谢谢 问题已解决
您客气了,服务您是我们的荣幸。
