本人刚学CUDA的小菜,CUDA4.0和opencv2.3.1已经分别设定好了。
请问opencv也写在.cu里吗? 我用网上的sample试了试,貌似不行,跪求具体步骤
注 本人运行2楼的程序时,出现以下错误
Project : error PRJ0019: ツールはエラー コードを返しました : “Compiling with CUDA Build Rule…”
不好意思,用的日文版的
注 本人运行2楼的程序时,出现以下错误
不好意思,用的日文版的
#include “cv.h”
#include “cxcore.h”
#include “highgui.h”
#pragma comment(lib,“cv.lib”)
#pragma comment(lib,“cxcore.lib”)
#pragma comment(lib,“highgui.lib”)
#include <cutil.h>
global void bit1cpykernel(unsigned char *in, unsigned char *out, int width, int channels){
int x = blockDim.x * blockIdx.x + threadIdx.x;
int y = blockDim.y * blockIdx.y + threadIdx.y;
out[y * width * channels + x * channels + 0] = in[y * width * channels + x * channels + 0];
global void bit2cpykernel(unsigned char *in, unsigned char *out, int width, int channels){
out[y * width * channels + x * channels + 1] = in[y * width * channels + x * channels + 1];
global void bit3cpykernel(unsigned char *in, unsigned char *out, int width, int channels){
out[y * width * channels + x * channels + 2] = in[y * width * channels + x * channels + 2];
global void bit4cpykernel(unsigned char *in, unsigned char *out, int width, int channels){
out[y * width * channels + x * channels + 3] = in[y * width * channels + x * channels + 3];
int main(int argc, char **argv){
CUT_DEVICE_INIT( argc, argv );
IplImage *imgin, *imgout;
unsigned char *d_in, *d_out;
int memsize;
imgin = cvLoadImage(“ファイルパス”);
imgout = cvCreateImage(cvSize(imgin->width, imgin->height), imgin->depth, imgin->nChannels);
printf(“width = %d, height = %d, nChannels = %d\n”, imgin->width, imgin->height, imgin->nChannels);
memsize = imgin->width * imgin->height * imgin->nChannels;
CUDA_SAFE_CALL(cudaMalloc((void**)&d_in, memsize));
CUDA_SAFE_CALL(cudaMalloc((void**)&d_out, memsize));
CUDA_SAFE_CALL(cudaMemcpy(d_in, imgin->imageData, memsize, cudaMemcpyHostToDevice));
dim3 threads(32,8);
dim3 blocks(imgin->width / threads.x, imgin->height / threads.y);
// 前の情報を一旦初期化(処理されなかったメモリは、前のデータが表示されるため)
// デバッグ用。通常は必要なし
cudaMemset(d_out, 0, memsize);
CUDA_SAFE_CALL( cudaThreadSynchronize() );
unsigned int timer = 0;
CUT_SAFE_CALL( cutCreateTimer( &timer));
CUT_SAFE_CALL( cutStartTimer( timer));
switch(imgin->nChannels){
case 1:
bit1cpykernel<<< blocks, threads >>> (d_in, d_out, imgin->width, imgin->nChannels);
break;
case 2:
bit2cpykernel<<< blocks, threads >>> (d_in, d_out, imgin->width, imgin->nChannels);
break;
case 3:
bit3cpykernel<<< blocks, threads >>> (d_in, d_out, imgin->width, imgin->nChannels);
break;
case 4:
bit4cpykernel<<< blocks, threads >>> (d_in, d_out, imgin->width, imgin->nChannels);
break;
// 同期をとる。
CUT_SAFE_CALL( cutStopTimer( timer));
printf(“処理時間: %f (ms)\n”, cutGetTimerValue( timer));
CUT_SAFE_CALL( cutDeleteTimer( timer));
CUDA_SAFE_CALL(cudaMemcpy(imgout->imageData, d_out, memsize, cudaMemcpyDeviceToHost));
cvNamedWindow(“in”, 1);
cvNamedWindow(“out”, 1);
cvShowImage(“in”, imgin);
cvShowImage(“out”, imgout);
// キーを何か押したら終了
cvWaitKey(-1);
cvDestroyWindow(“in”);
cvDestroyWindow(“out”);
cvReleaseImage(&imgin);
cvReleaseImage(&imgout);
cudaFree(d_in);
cudaFree(d_out);
请问您配置好了吗?我也想用CUDA4.0和opencv2.3.1,请指教!
