CUDA 5.0没有了cutil_inline.h怎么办?
因为电脑前些日子装了CUDA 5.0,发现运行以前含有cutil.h头文件的代码出问题了,百度了一下,说是5.0不再支持这些头文件了,现在该怎么办呢?
#include "cuda_runtime.h"
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "cutil_inline.h"
texture<float, 2, cudaReadModeElementType> texRef;
__global__ void transformKernel(float* output, int width, int height, float theta)
// Calculate normalized texture coordinates
unsigned int x = blockIdx.x * blockDim.x + threadIdx.x;
unsigned int y = blockIdx.y * blockDim.y + threadIdx.y;
float u = x / (float)width;
float v = y / (float)height;
// Transform coordinates
u -= 0.5f;
v -= 0.5f;
float tu = u*cosf(theta)- v*sinf(theta) + 0.5f;
float tv = v*cosf(theta)+ u*sinf(theta) + 0.5f;
// Read from texture and write to global memory
output[y * width + x] = tex2D(texRef, tu, tv);
// Host code
int main()
  float angle = 0.5f; // angle to rotate image by (in radians)
  // load image from disk
  float* h_data = NULL;
  unsigned int width, height;
  cutLoadPGMf("lena_bw.pgm", &h_data, &width, &height);
  // Allocate CUDA array in device memory
  cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
  cudaArray* cuArray;
  cudaMallocArray(&cuArray, &channelDesc, width, height);
   // Copy to device memory some data located at address h_data
   // in host memory
  unsigned int size = width * height * sizeof(float);
  cudaMemcpyToArray(cuArray, 0, 0, h_data, size, cudaMemcpyHostToDevice);
// Set texture parameters
texRef.addressMode[0] = cudaAddressModeWrap;
texRef.addressMode[1] = cudaAddressModeWrap;
texRef.filterMode = cudaFilterModeLinear;
texRef.normalized = true;
// Bind the array to the texture reference
cudaBindTextureToArray(texRef, cuArray, channelDesc);
// Allocate result of transformation in device memory
float* output;
cudaMalloc(&output, width * height * sizeof(float));
// Invoke kernel
dim3 dimBlock(16, 16);
dim3 dimGrid(width / dimBlock.x, height / dimBlock.y);
transformKernel<<<dimGrid, dimBlock>>>(output, width, height, angle);
// Free device memory
cudaFreeArray(cuArray);
cudaFree(output);
因为没有了07.#include “cutil_inline.h”,所以我就用5.0中的#include “helper_image.h”,并且将cutLoadPGMf()改成 sdkLoadPGM(),但是仍然提示错误!!!
错误如下:
1>MSVCRTD.lib(crtexe.obj) : error LNK2019: 无法解析的外部符号 _main,该符号在函数 ___tmainCRTStartup 中被引用
1>E:\Visual C++ 2010\CudaPractice\Debug\CudaPractice.exe : fatal error LNK1120: 1 个无法解析的外部命令
任何时候都不推荐你用例子里面的那些cut*开头的例程/宏,他们不是CUDA的一部分。
根据多年的经验看,错误的抄袭/使用它们带来的负面后果远远大于正面作用。不建议你使用。
同时,如同NV在说明里的说法一样,我也不对这些非CUDA的API/宏给予任何技术支持。
建立立刻停止使用。
此外,说找不到main()的话,请注意:
(0)您的代码是否含有main函数
(1)main所在的文件是否参与编译,
(2)该文件是否成功的生成.obj文件
(3)该.obj文件是否参与链接。
您的2楼的最后一个信息表明,连接器没有找到_main(cdecl, x86,从前缀和后缀推断),而不是编译错误。
好的。以后我会注意的。
我发现我的文件夹里没有生成.obj文件~
嗯嗯。那就想办法继续找到为何导致没有生成.obj, 一个较大的可能是该文件忘记参与编译了?(不要笑,当你找不到理由的时候不妨考虑这条)。
版主,您太好了啊!!!!
最近还行,你还好吗?
刚开始学,1000次kernel循环就会出现蓝屏死机现象,但是数据传递又出现很大的delay!!!!哎!
这个已经给你解释过了,请看你的原帖我的回复。
