arducam相机在 jetson Orin Nano上无法运行最大分辨率 运行不到五秒就管道崩溃是咋回事,那位大神知道原因,在线等。
请使用下面的模版提问(创建话题后勾选相应的选项):
Jetson 模组
Jetson AGX Orin
Jetson Orin NX
[1] Jetson Orin Nano
Jetson AGX Xavier
Jetson Xavier NX
Jetson TX 系列
Jetson Nano
Jetson 软件
JetPack 5.1.3
JetPack 5.1.4
JetPack 6.0
JetPack 6.1
DeepStream SDK
NVIDIA Isaac
SDK Manager 管理工具版本
2.1.0
其他
问题描述
<请在此处提供问题描述/复现步骤/用例/图片的详细信息 >
c@ubuntu:~/MIPI_Camera/Jetson/IMX477/AF_LENS$ python3 camera_test.py -i 9
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4032 x 3040 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 4032 H = 3040
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[ WARN:0] global /home/ubuntu/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (1100) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
CONSUMER: ERROR OCCURRED
[ WARN:1] global /home/ubuntu/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (624) isPipelinePlaying OpenCV | GStreamer warning: unable to query pipeline state
[ WARN:1] global /home/ubuntu/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (2075) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc0 reported: TIMEOUT
GST_ARGUS: Cleaning up
[ WARN:1] global /home/ubuntu/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (2075) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc0 reported: Internal data stream error.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:858 NULL SensorMode interface detected
(Argus) Error InvalidState: (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThread(), line 134)
(Argus) Error InvalidState: (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThreadStatic(), line 176)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:336 Stream failed to connect.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
段错误 (核心已转储)
错误码
< 填写错误码(无需其他信息) >
错误日志
请粘贴错误日志文本(尽量粘贴错误文本,而不是截图)
请在此处粘贴完整的程序日志。如果有多个日志,请使用多个文本框
