cudamemcpy2D与cudaMallocPitch使用问题
程序就是两个二维数组相加,cudamemcpy2D与cudaMallocPitch好像在处理数据的时候不对,调了一天了结果始终不对,跪求前辈指点,代码如下:
#include “cuda_runtime.h”
global void addKernel(int **c, int **a, int **b)
int i = threadIdx.x;
int j = threadIdx.y;
c[i][j] = a[i][j] + b[i][j];
int main()
int **a;
int **b;
int **c;
int row,col;
// Add vectors in parallel.
int **dev_a;
int **dev_b;
int **dev_c;
int width=5,height=5;
size_t size=sizeof(int)*width;
size_t pitcha,pitchb,pitchc;
a= new int *[height];
b=new int *[height];
c=new int *[height];
for (row=0;row<height;row++)
	a[row]=new int[width];
	b[row]=new int[width];
	c[row]=new int[width];
	for (col=0;col<width;col++)
		a[row][col]=(row+1)*(col+1);
		b[row][col]=10*(row+1)*(col+1);
		c[row][col]=0;
for(int i=0;i<5;i++){
	for(int j=0;j<5;j++)
		printf("%4d",a[i][j]);
	printf("\n");
		printf("%4d",b[i][j]);
	printf("\n");
cudaMallocPitch((void**)&dev_a,&pitcha,size,height);
cudaMallocPitch((void**)&dev_b,&pitchb,size,height);
cudaMallocPitch((void**)&dev_c,&pitchc,size,height);
cudaMemset2D(dev_a, pitcha, 0, size, height);
cudaMemset2D(dev_b, pitchb, 0, size, height);
cudaMemset2D(dev_c, pitchc, 0, size, height);
cudaMemcpy2D(dev_a,pitcha,a,size,size,height,cudaMemcpyHostToDevice);
cudaMemcpy2D(dev_b,pitchb,b,size,size,height,cudaMemcpyHostToDevice);
dim3 dimBlock(5,5);
addKernel<<<1,dimBlock>>>(dev_c,dev_a,dev_b);
cudaMemcpy2D(c,size,dev_c,pitchc,size,height,cudaMemcpyDeviceToHost);
		printf("%4d",c[i][j]);
	printf("\n");
cudaFree(dev_a);
cudaFree(dev_b);
cudaFree(dev_c);
// cudaDeviceReset must be called before exiting in order for profiling and
// tracing tools such as Nsight and Visual Profiler to show complete traces.
楼主,你不能构建一个缓冲区的数组,然后再尝试一次性合并。那是不对的。。。
你需要一个连续的数组/缓冲区,而不是分散的行数为数目的n个分散缓冲区!!!
你那样实际上是指针的数组。。每个指针指向一个缓冲区。这是不对的。
请详见此贴:http://cudazone.nvidia.cn/forum/forum.php?mod=viewthread&tid=6525&extra=page%3D1
cudaMallocPitch分配出来的实际是线性内存,但是和二维数组是有区别的,参数pitch是分配的每一行的长度,而你真实情况下,有可能你实际使用一行的长度是小于这个pitch的,pitch分配主要是为了对齐内存而使用的但绝非二维数组。
比如你分配250个BYTE一行,用pitch分配出来,一行实际大小为256,如果你用二维数组的方式访问254这个元素的时候,那么你实际访问的不是你的有效数据区域,而是跑到了额外用于对齐的位置,而这部分是没有赋值过的。
