我运行Udacity 的Introduction to Parallel Programming课程上的一个例子:
#include "gputimer.h"
#define NUM_THREADS 1000000
#define ARRAY_SIZE 100
#define BLOCK_WIDTH 1000
void print_array(int *array, int size)
printf("{ ");
for (int i = 0; i < size; i++) { printf("%d ", array[i]); }
printf("}\n");
__global__ void increment_naive(int *g)
// which thread is this?
int i = blockIdx.x * blockDim.x + threadIdx.x;
// each thread to increment consecutive elements, wrapping at ARRAY_SIZE
i = i % ARRAY_SIZE;
g[i] = g[i] + 1;
__global__ void increment_atomic(int *g)
i = i % ARRAY_SIZE;
atomicAdd(& g[i], 1);
int main(int argc,char **argv)
GpuTimer timer;
printf("%d total threads in %d blocks writing into %d array elements\n",
NUM_THREADS, NUM_THREADS / BLOCK_WIDTH, ARRAY_SIZE);
// declare and allocate host memory
int h_array[ARRAY_SIZE];
const int ARRAY_BYTES = ARRAY_SIZE * sizeof(int);
// declare, allocate, and zero out GPU memory
int * d_array;
cudaMalloc((void **) &d_array, ARRAY_BYTES);
cudaMemset((void *) d_array, 0, ARRAY_BYTES);
// launch the kernel - comment out one of these
timer.Start();
increment_naive<<<NUM_THREADS/BLOCK_WIDTH, BLOCK_WIDTH>>>(d_array);
//increment_atomic<<<NUM_THREADS/BLOCK_WIDTH, BLOCK_WIDTH>>>(d_array);
timer.Stop();
// copy back the array of sums from GPU and print
cudaMemcpy(h_array, d_array, ARRAY_BYTES, cudaMemcpyDeviceToHost);
print_array(h_array, ARRAY_SIZE);
printf("Time elapsed = %g ms\n", timer.Elapsed());
// free GPU memory allocation and exit
cudaFree(d_array);
发现我的机器最后得出的结果全是0(代码本身没有问题),机器配置是GT240M + vs2008 ,运行结果如图
请问是什么情况导致了这种问题?
