cudaerror_enum问题
在执行cuda程序时遇到cudaerror_enum问题
.exe中的***处最可能的异常Microsoft C++异常:内存位置*****处的cudaerror_enum
想问问有可能是什么原因,本电脑用vs2010 cudav5.0 显卡是gt9600
但问题是同样的代码在vs2010 cudav5.0 显卡是gt640上跑是没问题的。
而且出错的很不确定,就是我是循环使用一个函数,里面有cuda的代码,但有时循环了40多次然后出错了,有时循环了50多次然后出错,每次都不太确定。
下面贴一些出错的代码
void reconstruction::X_image_display::iterative_project_point()
//这里部分代码省略
for(int i=0;i<5;i++)
output_node->find_corresponding(data_inf->vertex_dev,data_inf->normal_dev,data_inf->
corresponding_vertex_dev,data_inf->corresponding_normal_dev,data_inf->cor_juedge_dev);
data_inf->get_rotation_transfer(900,0.7,data_inf->cor_juedge_dev);//这一句出错了
data_inf->transf();
//下面部分代码省略
void reconstruction::save_output_image::find_corresponding(zuobiao *vertex,zuobiao *normal,zuobiao *corresponding_vertex,zuobiao *corresponding_normal,bool *cor_judge)
find_corresponding_dev(vertex,normal,corresponding_vertex,corresponding_normal,cor_judge,
this->volumn_,this->edgetable_dev,this->tritable_dev);
void reconstruction::find_corresponding_dev(zuobiao *vertex,zuobiao *normal,zuobiao *corresponding_vertex,zuobiao *corresponding_normal,bool *cor_judge,
float *volumn ,int *edgetable_dev,int *tritable_dev)
dim3 dimblock(256);
dim3 dimgrid(1200);
find_corresponding_dev_global<<<dimgrid,dimblock>>>(vertex,normal,corresponding_vertex,corresponding_normal,cor_judge,
volumn,edgetable_dev,tritable_dev);
//关键是这里如果用cudamemcpy把cor_judge分配到主机上没错
void reconstruction::data_information::get_rotation_transfer(float thr1,float thr2,bool *corjudge)
get_r_t_dev(this->vertex_dev,this->corresponding_vertex_dev,this->corresponding_normal_dev,this->
cor_juedge_dev,this->rotation,this->transfer,thr1,thr2);
void reconstruction::get_r_t_dev(zuobiao vertex,zuobiao corresponding_vertex,zuobiao corresponding_normal,bool cor_judge,float rotation,float transfer,float thr1,float thr2)
//但这里如果用cudamemcpy把cor_judge分配到主机上也出错了,cor_judge原本是存储在显卡里的
float a_,t_;
a_=new float[1200
6
6];
t_=new float[1200
6];
for(int i=0;i<1200;i++)
for(int j=0;j<6;j++)
t_[i*6+j]=0;
for(int k=0;k<6;k++)
a_[i*6*6+j*6+k]=0;
float a_dev,t_dev;
cudaMalloc(&a_dev,1200
6
6
sizeof(float));
cudaMalloc(&t_dev,1200
6
sizeof(float));
cudaMemcpy(a_dev,a_,1200
6
6sizeof(float),cudaMemcpyHostToDevice);
cudaMemcpy(t_dev,t_,1200
dim3 dimblock(256);
dim3 dimgrid(1200);
get_r_t_dev_global<<<dimgrid,dimblock,2000
sizeof(float)>>>(vertex,corresponding_vertex,corresponding_normal,
cor_judge,a_dev,t_dev,thr1,thr2);//这一句出错了
cudaMemcpy(a_,a_dev,120066sizeof(float),cudaMemcpyDeviceToHost);
cudaMemcpy(t_,t_dev,1200
6*sizeof(float),cudaMemcpyDeviceToHost);
cudaFree(a_dev);
cudaFree(t_dev);
//一下代码省略
想请问一下知道是什么原因吗???
LZ您好,不妨先参阅一下如下的帖子:
http://cudazone.nvidia.cn/forum/forum.php?mod=viewthread&tid=6426
我看过了,但自己没有写宏,用cudaGetLastError()返回的是unknow error所以还是不知道怎么搞
1:最可能的异常Microsoft C++异常(first chance exception),这个是给调试器的信息,所以您这里可能并无实际问题,如同之前的链接所说。
2:如果您自己使用cudaGetLastError()得到返回的是unknow error,这个有可能是访存越界了,请您加以检查。
3:以及,您可以一步步检查返回值以定位问题所在的地方。
您可以:
a:对于一般cudaMemcpy等同步操作,直接检查函数的返回值,看看每个操作是否正确执行了。
b:对于kernel发布这种异步的操作,您可以在发布后添加cudaDeviceSynchronize()函数,并检测此函数的返回值。
c:因为cudaGetLastError()有自己的缓存机制,以及CUDA中异步操作失败后会导致后面所有的操作都失败,所以您用cudaGetLastError()定位问题可能不如a:b:联用准确和方便。
大致如此,建议您逐步检查下问题所在。
以及关于逐步查错和cudaGetLastError()的讨论,请您移步如下帖子,主要结论在16#~19#。
http://cudazone.nvidia.cn/forum/forum.php?mod=viewthread&tid=6514&extra=&page=2
