cuda samples中的有一个scan 的例子 好像是有关前缀求和 没太看明白 请教大家在这里他主要实现的功能是不是数列中的前缀求和问题 具体的位置是:\ProgramData\NVIDIA Corporation\CUDA Samples\v5.0\6_Advanced
代码如下
* Copyright 1993-2012 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
#include <assert.h>
#include <helper_cuda.h>
#include "scan_common.h"
//All three kernels run 512 threads per workgroup
//Must be a power of two
#define THREADBLOCK_SIZE 256
// Basic ccan codelets
//Naive inclusive scan: O(N * log2(N)) operations
//Allocate 2 * 'size' local memory, initialize the first half
//with 'size' zeros avoiding if(pos >= offset) condition evaluation
//and saving instructions
inline __device__ uint scan1Inclusive(uint idata, volatile uint *s_Data, uint size)
uint pos = 2 * threadIdx.x - (threadIdx.x & (size - 1));
s_Data[pos] = 0;
pos += size;
s_Data[pos] = idata;
for (uint offset = 1; offset < size; offset <<= 1)
uint t = s_Data[pos] + s_Data[pos - offset];
s_Data[pos] = t;
return s_Data[pos];
inline __device__ uint scan1Exclusive(uint idata, volatile uint *s_Data, uint size)
return scan1Inclusive(idata, s_Data, size) - idata;
inline __device__ uint4 scan4Inclusive(uint4 idata4, volatile uint *s_Data, uint size)
//Level-0 inclusive scan
idata4.y += idata4.x;
idata4.z += idata4.y;
idata4.w += idata4.z;
//Level-1 exclusive scan
uint oval = scan1Exclusive(idata4.w, s_Data, size / 4);
idata4.x += oval;
idata4.y += oval;
idata4.z += oval;
idata4.w += oval;
return idata4;
//Exclusive vector scan: the array to be scanned is stored
//in local thread memory scope as uint4
inline __device__ uint4 scan4Exclusive(uint4 idata4, volatile uint *s_Data, uint size)
uint4 odata4 = scan4Inclusive(idata4, s_Data, size);
odata4.x -= idata4.x;
odata4.y -= idata4.y;
odata4.z -= idata4.z;
odata4.w -= idata4.w;
return odata4;
// Scan kernels
__global__ void scanExclusiveShared(
uint4 *d_Dst,
uint4 *d_Src,
uint size
__shared__ uint s_Data[2 * THREADBLOCK_SIZE];
uint pos = blockIdx.x * blockDim.x + threadIdx.x;
//Load data
uint4 idata4 = d_Src[pos];
//Calculate exclusive scan
uint4 odata4 = scan4Exclusive(idata4, s_Data, size);
//Write back
d_Dst[pos] = odata4;
//Exclusive scan of top elements of bottom-level scans (4 * THREADBLOCK_SIZE)
__global__ void scanExclusiveShared2(
uint *d_Buf,
uint *d_Dst,
uint *d_Src,
uint N,
uint arrayLength
//Skip loads and stores for inactive threads of last threadblock (pos >= N)
//Load top elements
//Convert results of bottom-level scan back to inclusive
uint idata = 0;
if (pos < N)
idata =
d_Dst[(4 * THREADBLOCK_SIZE) - 1 + (4 * THREADBLOCK_SIZE) * pos] +
d_Src[(4 * THREADBLOCK_SIZE) - 1 + (4 * THREADBLOCK_SIZE) * pos];
//Compute
uint odata = scan1Exclusive(idata, s_Data, arrayLength);
//Avoid out-of-bound access
if (pos < N)
d_Buf[pos] = odata;
//Final step of large-array scan: combine basic inclusive scan with exclusive scan of top elements of input arrays
__global__ void uniformUpdate(
uint4 *d_Data,
uint *d_Buffer
__shared__ uint buf;
if (threadIdx.x == 0)
buf = d_Buffer[blockIdx.x];
uint4 data4 = d_Data[pos];
data4.x += buf;
data4.y += buf;
data4.z += buf;
data4.w += buf;
d_Data[pos] = data4;
// Interface function
//Derived as 32768 (max power-of-two gridDim.x) * 4 * THREADBLOCK_SIZE
//Due to scanExclusiveShared<<<>>>() 1D block addressing
extern "C" const uint MAX_BATCH_ELEMENTS = 64 * 1048576;
extern "C" const uint MIN_SHORT_ARRAY_SIZE = 4;
extern "C" const uint MAX_SHORT_ARRAY_SIZE = 4 * THREADBLOCK_SIZE;
extern "C" const uint MIN_LARGE_ARRAY_SIZE = 8 * THREADBLOCK_SIZE;
extern "C" const uint MAX_LARGE_ARRAY_SIZE = 4 * THREADBLOCK_SIZE * THREADBLOCK_SIZE;
//Internal exclusive scan buffer
static uint *d_Buf;
extern "C" void initScan(void)
checkCudaErrors(cudaMalloc((void **)&d_Buf, (MAX_BATCH_ELEMENTS / (4 * THREADBLOCK_SIZE)) * sizeof(uint)));
extern "C" void closeScan(void)
checkCudaErrors(cudaFree(d_Buf));
static uint factorRadix2(uint &log2L, uint L)
if (!L)
log2L = 0;
else
for (log2L = 0; (L & 1) == 0; L >>= 1, log2L++);
return L;
static uint iDivUp(uint dividend, uint divisor)
return ((dividend % divisor) == 0) ? (dividend / divisor) : (dividend / divisor + 1);
extern "C" size_t scanExclusiveShort(
uint *d_Dst,
uint *d_Src,
uint batchSize,
uint arrayLength
//Check power-of-two factorization
uint log2L;
uint factorizationRemainder = factorRadix2(log2L, arrayLength);
assert(factorizationRemainder == 1);
//Check supported size range
assert((arrayLength >= MIN_SHORT_ARRAY_SIZE) && (arrayLength <= MAX_SHORT_ARRAY_SIZE));
//Check total batch size limit
assert((batchSize * arrayLength) <= MAX_BATCH_ELEMENTS);
//Check all threadblocks to be fully packed with data
assert((batchSize * arrayLength) % (4 * THREADBLOCK_SIZE) == 0);
scanExclusiveShared<<<(batchSize * arrayLength) / (4 * THREADBLOCK_SIZE), THREADBLOCK_SIZE>>>(
(uint4 *)d_Dst,
(uint4 *)d_Src,
arrayLength
getLastCudaError("scanExclusiveShared() execution FAILED\n");
return THREADBLOCK_SIZE;
extern "C" size_t scanExclusiveLarge(
uint *d_Dst,
uint *d_Src,
uint batchSize,
uint arrayLength
uint log2L;
assert((arrayLength >= MIN_LARGE_ARRAY_SIZE) && (arrayLength <= MAX_LARGE_ARRAY_SIZE));
(uint4 *)d_Dst,
(uint4 *)d_Src,
//Not all threadblocks need to be packed with input data:
//inactive threads of highest threadblock just don't do global reads and writes
const uint blockCount2 = iDivUp((batchSize * arrayLength) / (4 * THREADBLOCK_SIZE), THREADBLOCK_SIZE);
scanExclusiveShared2<<< blockCount2, THREADBLOCK_SIZE>>>(
(uint *)d_Buf,
(uint *)d_Dst,
(uint *)d_Src,
(batchSize *arrayLength) / (4 * THREADBLOCK_SIZE),
arrayLength / (4 * THREADBLOCK_SIZE)
getLastCudaError("scanExclusiveShared2() execution FAILED\n");
uniformUpdate<<<(batchSize *arrayLength) / (4 * THREADBLOCK_SIZE), THREADBLOCK_SIZE>>>(
(uint4 *)d_Dst,
(uint *)d_Buf
getLastCudaError("uniformUpdate() execution FAILED\n");
